Which is better? Stock 350 Heads, or Swirl-Port Heads
Old Aug 28, 2011 | 04:18 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
So which one flows better guys? Gonna hit the junkyard soon so I need some advice. Thanks guys.
Old Aug 28, 2011 | 09:19 AM
Re: Which is better? Stock 350 Heads, or Swirl-Port Heads
Depends on which "stock" 350 heads you're talking about.
Swirlies are "stock" too, you know.
But they are pretty much the worst for flow.
OTOH, most other "stock" 350 heads have other problems that don't make them any more "desirable".
What's wrong with your existing 083s?
Old Aug 28, 2011 | 11:28 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Tell us what exactly you are trying to accomplish and go from there.
Old Aug 28, 2011 | 12:12 PM
Soon I'm gonna buy a edelbrock runner set. I already have the hi flow base. Currently I have the swirl port heads in my IROC. Since I'm gonna pull the OEM intake manifold, I might as well pull the crappy heads too. So I was thinking about pulling some non swirl port heads from a junkyard that has an advantage over my swirlies. I'm just not sure if the "stock iroc heads" are better than the junk I have now. Why am I getting stock heads you may ask? Because I'm low on cash.
Old Aug 28, 2011 | 02:29 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Stock IROC heads are much better. Make sure they're 083 heads.
Old Aug 28, 2011 | 03:54 PM
Sweet. Thanks. Now I'm gonna investigate what are 083 heads. Thanks man.
Old Aug 28, 2011 | 04:03 PM
ex-x-fire's Avatar
Vortecs are the best!
Old Aug 28, 2011 | 07:00 PM
89RsPower!'s Avatar
083 refers to the last 3 digits of the casting number on the head.
Old Aug 28, 2011 | 07:02 PM
89RsPower!'s Avatar
He's low on cash and already has an edelbrock base, tho I suppose he could sell it and get one for vortecs...
Old Aug 28, 2011 | 07:47 PM
89RsPower!, Thanks for getting my back. Im gonna stay with my Edelbrock intake and Ill probably get the 083 heads. Im sure I can find them relatively cheap.
Old Aug 28, 2011 | 09:15 PM
Car: 1992 Camaro RS
083 are IROC 350 L98 heads. They are, basically, 350 IROC heads. The ones you'd want. They should be cheap and common and they're an improvement. i would expect around 20hp from them, more if you do something like an LT4 hotcam swap. They are fairly cheap, but cam swaps will always nickel and dime you to death if you're not careful.
Either way, just those heads should help by themselves.
Vortecs are excellent heads, but sicne you already have a normal pattern manifold, I'd save the money you would have spent on vortec heads and parts for a cam swap if you just want to blow an extra $300. A Hotcam setup will make for a very nice running engine.
Old Aug 28, 2011 | 09:21 PM
InfernalVortex, Thanks for the info. Yeah man I already have the normal Edelbrock Hi FLow base. Im planning on buying a set of 083's and having them P & P until I can afford a set of aluminums. I already have a LT1 cam stabbed in my block. So the cam is good to go.
Old Aug 28, 2011 | 11:00 PM
Car: 1992 Camaro RS
The LT1 cam is a good improvement, but the hotcam is bigger than the regular LT1 cam. It's 218/228 @ .050 and .500/.500 with 1.5 rockers and .525/.525 with 1.6 rockers.
Old Aug 28, 2011 | 11:04 PM
But is the Hotcam compatible with my OEM MemCal? I stabbed the LT1 Cam because I read that the LT1 is a good upgrade and that it is compatible (Computer Controlled).
Old Aug 28, 2011 | 11:07 PM
Car: 1992 Camaro RS
It will take more work and be a bigger PITA, but more power is always a bigger pain in the ***.
But it was a GM Performance Parts upgrade for the LT1 guys to put on their corvettes and Camaros. It may not be compatible with your stock tune, but it is possible to program your ecm to run it. It's GM's cam.
Im not saying you SHOULD do it. you've got a decent cam and you've got decent heads. But if you have the urge to push things a little farther, those Hotcams are available and relatively cheap if you can find one used. It's a good cheap way to get a big roller cam. Do some research on whether 083 heads can handle that much lift, but remember with stock rockers it will only be .500 lift, not .525.
http://www.youtube.com/watch?v=BdXg4xbnJvw
Old Aug 28, 2011 | 11:13 PM
Alright. That is well worth the investigation. Yeah. I was looking at the Scorpion 1.6 S/A RR and the Comp Cams Magnum 1.6 S/A RR too. But I gotta take things one at a time. Time is money and money is tight. But I will get the job done in time. I apreciate the help and advice InfernalVortex. Thank you so much.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
