84 Camaro won't start
When I turn the key car does nothing. It gets power to the the accessories but will not crank, click, nothing. Replaced the ignition switch, key cylinder, starter, battery, fusible links, nuetral safety switches, relay for shifter (B & M), alternator, and a new hot start relay.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 84 Camaro won't start
Check the purple wire on the starter for voltage when the key is turned.
Also, you replaced the starter - did you get the starter wiring reconnected correctly? ALL wires including pos battery wire go on the larger terminal, ONLY the purple wire goes on the smaller terminal.
92camaroJoe
Aug 13, 2015 06:07 AM
