Is this cracked head good?
Old Aug 30, 2011 | 12:04 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I was browsing a auction site and I found this cylinderhead. It has a crack where the 2 center exhaust port are. Would you buy these head? Is it wise to use the heads?
Old Aug 31, 2011 | 04:04 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Is this cracked head good?
Kind of odd that theres a liner in that center bolt hole. Not quite sure what they where trying to accomplish. If it runs the whole way, the bolt would end up loading the liner, and not necessarily the cylinder head in that one spot since its not really a press fit with a large crack on both sides of it. Id probably steer clear of them since the liner is creating additional cracks really close to where the fire rings are, not to mention the water jacket.
If there where no liner, they could be fixed by a good machine shop if the crack didnt go too far into the deck.
Old Sep 1, 2011 | 02:07 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I wouldn't trust that at all! That crack is into the water jacket!
Old Sep 1, 2011 | 02:11 PM
Thats what I thought too.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
