What emission components cam on a 1984 Trans Am
Old Aug 30, 2011 | 10:04 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Hey Everyone. I am looking at buying a 1984 Trans Am to replace my 1991 Firebird. The car has had a vortec 350 with a carb swapped into it. Obviously all the emission stuff has been removed except for the cat. Now my current car has a smog pump, egr, A.I.R. tubes, etc. My question is which components were on the 1984 originally? I had an 84 before and I know it had a cat and an egr valve but I don't remember a smog pump or A.I.R. tubes. I'm just trying to find out what the state inspector might flag for not being there. Any help would be greatly appreciated. Thanks!
Old Aug 31, 2011 | 12:57 PM
Guest
Guest
Posts: n/a
Re: What emission components cam on a 1984 Trans Am
You will need the smog pump. You can have EGR with Vortec heads and a Q-Jet using the GMPP manifold 12496820. You'll also need PCV, evap, and thermostatic air cleaner.
Old Aug 31, 2011 | 03:00 PM
Wiggles's Avatar
Car: 84 Firebird, 78 Trans Am
Engine: LG4 305 Qjet, Pontiac 400cid
Transmission: T5 Non WC, TH350
Axle/Gears: All stock
My 84 is bone stock and has charcoal evap canister, smog pump, A.I.R. tubes on both exhaust manifolds, 2 A.I.R. check valves, A.I.R. diverter valve, EGR and EGR solenoid. It also has a PCV valve and the THERMAC air cleaner as well. I guess it also depends on what state you live in and how strict they are towards emissions components. Here in Arizona, they do check under the hood but are mainly looking for the evap can, smog pump and A.I.R. tubes. Here is a color coded diagram that I redrew in Photoshop..it should help.
Old Aug 31, 2011 | 05:19 PM
Guest
Guest
Posts: n/a
I might could try to post a pic of the sticker on my '84 Z28 LG4, but it might not show well, as my regular camera won't work anymore, so I'm reduced to my cellphone camera.
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
and I have every single part you need
Old Sep 4, 2011 | 11:55 AM
omnivec's Avatar
Car: 85 Z51 Corvette
Transmission: Manual 4+3
Axle/Gears: Dana 44 3.73
Dont forget that shity efe (early fuel evaporation) valve, on the passenger exhaust pipe. CA smog shops want to see that as well.
Old Sep 4, 2011 | 01:02 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The 50 state emission legal Hooker 2055's don't have that...just the air tubes.
My 84 T/A, as mentioned above...charcoal evap canister, smog pump, A.I.R. tubes on both exhaust manifolds, 2 A.I.R. check valves, A.I.R. diverter valve, EGR and EGR solenoid. It also has a PCV valve and the THERMAC air cleaner as well. Mine is a 350 as well, moderate build, and it barely passes the emissions here in the UK...not sure how they differ from Cali though. I know were I back home in minnesota, I'd lose the Cat, AIR tubes, smog pump and EGR valve because no emissions there.
Jorlain
Aug 24, 2022 05:11 PM
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
nuggie
Aug 25, 2015 01:27 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
