intermittent starter problems?!?!
Old Aug 31, 2011 | 09:59 AM
ewskater92's Avatar
Car: 1986 IROC-Z28 Camaro
Engine: 350 carbureted (swap from 305 TPI)
Transmission: 700R4 rebuilt with shift kit
I installed a new mini torque starter on my engine. It was completely fine w/o shims for the first 2 or 3 months. Now, occasionally when the engine is hot, it will make loud clanking noises when I go to start it. It seems to do this more often when the engine is hot. It starts just fine more often than not w/ no clanking noise. What could this be???
Old Aug 31, 2011 | 11:09 AM
ewskater92's Avatar
Re: intermittent starter problems?!?!
TTT... Anything???
Old Aug 31, 2011 | 12:49 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
If the starter gear comes out and just hits the flywheel without the starter gear spinning it'll make a metallic "Clank". You can duplicate this sound by unhooking the power wire that goes from the starter to the battery and putting power to the small tab where the purple wire attaches. Shimming problems usually have a grinding noise, not really a "clank" or "bang" type noise.
Do you have headers that are getting the starter solenoid too hot?
Old Aug 31, 2011 | 09:55 PM
ewskater92's Avatar
I do have some hooker super comp shorty headers on the car.
FreeSpirit
Aug 29, 2015 05:47 PM
mike_c
Aug 27, 2015 04:32 PM
CORV3TT3
Aug 23, 2015 11:26 AM
92camaroJoe
Aug 13, 2015 06:07 AM
