throttle cable trouble?
Old Sep 4, 2011 | 03:40 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I'm having problems with high idle after my engine has warmed up and I stop at the first light.I see this is a comon topic.Some have replaced alot of stuff and still have the trouble.How many of you have throttle cable trouble out there that you either lubed or replaced the cable and it fixed the problem?
Old Sep 5, 2011 | 03:57 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: throttle cable trouble?
High idle is generally a vacuum issue rather than a mechanical issue.
What are the specs on your motor, carbed or FI? What type of carb? Has anything else been done to the car or motor?
Old Sep 17, 2011 | 12:48 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
the engine is stock set up.I broke a little plastic T and temperarly taped it back together.It dose sound like there may be a vac line sucking air.Sort of sounds like it's in the rocker cover?
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
