Balancer timing mark in wrong spot common?
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
So I am attempting to set the timming on my 350. I borrowed an inductive timing light from my uncle that is from the 70's but has been hardly used. Until now I had just timed it by ear and the car runs pretty well. So upon setting everything up, with the engine running well, the mark lights up way towards the passenger side of the vehicle. Like as if the initial timing is like 50 degrees advanced or something. My harmonic balancer is about 15 years old, but I havn't ran the car a hole lot since I built the engine. I know factory type balancers can shift, but my question is how common is that. Does anyone know. I didn't think it would happen to mine, but that's all I can figure at the moment. Thanks.
Car: 1991 RS camaro
Engine: 5.7
Axle/Gears: peg leg for now
Re: Balancer timing mark in wrong spot common?
I don't know on your model, but I have a 91 and on the passenger side near the heater and ac dryer there is a brown/black stripe wire coming out of the harness. This put it in bypass. You disconnect it.
Engine: 40 over 350
Transmission: 86 T5
I am just running a regular HEI. It's not computer controlled, and I have the vacume advance disconected, and the hole pluged, so I think the timimg mark should be fairly close to my timimg tab.
"Shifting" (the outer ring breaking loose from the layer of spooge and wandering around) is VERY common.
If the motor runs right but the mark is out to lunch somewhere, ignore the mark. The engine does not whup out a timing light and check the mark, and run according to that; all it cares, is when the spark occurs. As long as it's right, it's happy.
IOW, if I may paraphrase one of The Great Ones in another unrelated field:
"If it RUNS good, it IS good".
Don't worry about some number; let THE ENGINE tell you what it wants.
It's not rocket science. Put it somewhere that it runs. See how it is. Move it. Better/worse? Better: move it some more the same way. Worse: move it the other way a little farther than you moved it the first way. Better/worse? Better: yadda yadda yadda until no further movement in either direction makes it any better.
Don't outsmart yourself, especially with a non-stock motor and unknown distributor; you have ABSOLUTELY NOT THE FAINTEST CLUE what the "right" timing IS, so what good is a light going to do? Just give the engine what it wants.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 40 over 350
Transmission: 86 T5
Thanks. I knew it could happen, but just wasn't sure. Thanks for the advise.
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Doesn't matter if the dist is 1 or 4 teeth off. It doesn't matter to the engine or the balancer. It fires when it fires. If you are off one or more teeth it just means you must rotate the top of the distributor so the #1 plug terminal is lined up with the rotor at TDC. If the mark is in the wrong spot I would suggest replacing the balancer as it has spun once and it will take less for it to spin again. One day it will fail and ruin your engine.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
LIL..............Your incorrect !
If the dist. is in a tooth or 4 off the timing mark will NOT line up with the
scale.
scale.
It can be off by 1 tooth or many, it will just require twisting the distributor to a very odd position to get the timing back to the point it will run properly.
Is this the original balancer on the motor? Like was said above, the outter ring can slip and throw off the timing reading (balancer is shot). OR.....
You could have a balancer/timing tab mismatch. GM put the timing tab in one of two positions: 12:00 (straight down behind the water pump) or 1:30 (peeking out under the driver's side leg of the water pump). The line on the balancer was in a different position to match the timing tab location. The difference between the two is about 40*. Very common when somebody swipes the balancer off an original 70s/80s era 305 carbureted or TBI engine (usually 12:00 postion balancer) and then shoves it on the front of a motor with a timing tab over in the 1:30 position. You end up reading about 50* advance when it's timed for good performance. It's not actually that advanced it reality, but that's how it reads when you put the timing gun to it.
Car: 91 rs
Engine: 305 tbi
I had a 77 Corvette years back that required putting the light on the number 2 (passenger side front) cylinder to get proper time... no clue why, it just worked that way. Engine was stock top to bottom, dist. Was in correctly plug wires on correctly everything was right but it threw the mark to the passenger side just like mentioned above... try it on the number 2 and see what happens
Engine: 40 over 350
Transmission: 86 T5
Engine: 40 over 350
Transmission: 86 T5
Engine: 40 over 350
Transmission: 86 T5
I have to agree with the other guys. I'm asuming your talking about the distributor gear at the botom of the shaft where it meets with the cam and oil pump right? I think you may have misunderstood the conversation - because if your dist was off a tooth I guess your timing could be off.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i was waiting on someone to point this out.it DOES matter where your timing marks are if it didnt GM wouldnt have put them there
Makes it faster for them to build and set up motors.Does it make em run "perfect"? "ideal"? "optimum"? REALLY???
