Timing Issue
Old Sep 9, 2011 | 06:42 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Timing Issue
I just replaced my LB9 with an L98 and had the distributor out. So I dropped the dist. back in lined up the rotor so it pointing to #1 cylinder and timing mark lined up at TDC. Got the car started up and was running fine. But when I put the timing light on it the mark was way off to the right around the 3 or 4 o'clock position. I did have the EST unplugged. I plugged it back in and it did the same thing. What could cause this? As far as I know everything is stock. Thanks
Old Sep 9, 2011 | 08:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Timing Issue
Rotor can point anywhere it points - BUT the #1 cylinder must be at TDC on the compression stroke. Then, wherever the rotor points, that HAS to be the corresponding plug wire for the #1 spark plug. If the rotor waqsn't pointing at #1 cylinder on TDC compression stroke before, doing that now doesn't do anything.
Remove #1 spark plug, place finger over hole, and have someone turn over engine manually until you feel the outward air pressure on your finger - then line up the balancer mark with zero - now the #1 piston is at TDC on the compression stroke. Then, remove dist cap, and wherever the rotor points, THAT corresponding plug wire MUST be the #1 spark plug - replace #1 spark plug, and rerun wires accordingly with firing order.
Old Sep 10, 2011 | 06:02 PM
bigj350's Avatar
Re: Timing Issue
As far as lining up the rotor, thats what I meant. I had it pointing at #1 wire. And I did check the compression stroke to make sure it was at TDC. I just don't understand why the car is running fine but my timing light is showing the mark 40 degrees off.
Old Sep 10, 2011 | 06:36 PM
ex-x-fire's Avatar
Re: Timing Issue
The harmonic balancer has been known to slip on sbc.
Make sure the #1 piston is all the way up, use a coat hanger to feel the piston. The mark should be very close to zero.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
