Problem with belts.
Old Sep 11, 2011 | 01:35 PM
Inlovewithan83's Avatar
Problem with belts.
I have a 1983 Chevy Camaro V6 engine.
The other day I did a burn out in my camaro and heard a knock in the engine when I lost power steering. I limped the car home and popped the hood to my coolant tank boiling and fan belts off (Minus the air because I tore that out). When I reattach the belts the alternator belt flips upside down, when I finally got the belts on and the engine running with the belts on and running I went to take it out to test drive it and as soon as I punched the gas the engine knocked and both belts came right off again. What's going on and what the heck did I do?? Help!!
Old Sep 11, 2011 | 08:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Problem with belts.
Belts need to be tighter. You should only be able to push the belt maybe 1/2 inch after install.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
