new flywheel and starter after swap...
Old Sep 11, 2011 | 10:15 PM
55mikey55's Avatar
Car: 92 sonoma
Engine: 1985 LB9 tpi, stock
Transmission: NV3500
Axle/Gears: g80, 4.11 posi
305 tpi into 92 s10, motor came with no starter or flywheel, so i had to guess at the shims for the starter. now, no start, have to buy a new flywheel, new starter and hope i can figure out how to shim he starter correctly this time. any input on how to do this?
looking for a gear reduction starter that's small enough to fit inside the frame rails, and maybe a re-ring kit for the flywheel
Old Sep 11, 2011 | 10:57 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: new flywheel and starter after swap...
flywheels are cheep like 25 bucks easy way to check is take a paper clip and straighten it out use a screwdriver to pull out the bendix (or remove the motor lead so the bendix kicks but dosent spin when the key is turned) and if the paper clip wire fits in and has a little resistance your good to go if not then shim it till it does. add shims to the frame rail side to move it closer inner bolt to move it out. Also get a brace or bracket for the front it really helps keep the starter from shifting side to side making it impossible to get the correct engagment.
Old Sep 11, 2011 | 11:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Assuming you have a 153 tooth flywheel
Factory Denso mini starter from '89 + Vette
http://cgi.ebay.com/ebaymotors/CHEVY...item3a69d83816
Old Sep 12, 2011 | 04:47 PM
55mikey55's Avatar
Car: 92 sonoma
where do you find flywheels for $25? mine's a 5 speed
3rd gen money
Oct 11, 2019 09:57 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Gordonr1973
Sep 29, 2015 11:59 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
