Oil Drain Plug Leak
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Oil Drain Plug Leak
Make sure you didn't strip the bolt and if so, fix it. Either get one of those rubber expanding plugs, over sized plug, or re-tap the hole to fit a bigger plug.
Car: 1987 Black IROC-Z (SOLD)
Thanks ...No cracks. I will go with the washer to stop that drain plug leak. It is like a small drop when the oil gets hot. Oil level stay full, (so how drops in a quart of oil?) it just a pain. I also know SBC are leakers.
Gasket sealers and fluids don't check the brand of the metal and decide accordingly whether to do their thing or not. Especially not oil drain plugs. Except for occasional crappy design details (*cough*SBC valve cover gaskets*cough*) they're all pretty much equal.Pans FREQUENTLY crack around the "nut" thing that's welded into the pan. ALL brands. More common than you might think. And, can be very hard to see, because the crack is usually circular and concentric with the hole.
I agree. Happened on my street bike. Until I took the pan off and replaced it, I never would have known there was a crack along the threads. But that could have been caused by me. Story for a different day.
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Before you go spending too much money and time, try replacing the gasket and drain plug if you haven't already. I had this problem on a VW at work. With a new gasket, the plug still leaked a tiny bit. When I looked at the collar of the drain plug, I found that it was slightly flattened on some parts. Replaced the gasket and drain plug.
Navy8125
Aug 21, 2015 09:32 AM
