Brake light indicator on
Old Sep 13, 2011 | 07:48 PM
lonesomeloser's Avatar
Car: 1983 Z28
Ever since my engine swap, the idiot light for the brakes is on. I also upgraded to a newer style prop valve along with the 4th gen rear. Any ideas?
Old Sep 13, 2011 | 08:07 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Brake light indicator on
Only 2 possibilities. Either air in the system or the park brake switch is tripped.
Since you changed some parts, my bet is air in the hydraulics. Bleed them again.
Old Sep 14, 2011 | 06:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
From the manual:
"The pressure differential warning switch is designed to constantly compare front and rear brake pressure from the master cylinder and energize the warning light on the dash in the event of a front or rear system failure. The valve and switch are so designed that the switch will latch in the "warning" position once a failure has occurred. The only way the light can be turned off is to repair the failure and apply a pedal force to develop approximately 450 psi line pressure."
I assume the wiring is attached to the combination valve.
JamesC
Old Sep 16, 2011 | 03:14 PM
Car: 1983 Z28
Update: Re-bled the brake system. Pedal feels much better and the dash light is off.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
