LM7 or LQ4
Old Sep 15, 2011 | 09:59 PM
alans91z's Avatar
Car: 1991 Z-28
Engine: Goodwrench 350, stock TPI
LM7 or LQ4
Ok, i just jumped off the deep end and bought a 67 camaro convertible. It currently has an LM7/4L60e in it, but its not wired in nor is the car completely finished. I located an Lq4 and 5 speed combo for $1k, should i consider swapping out the LM7/Eaton 5speed (i assume the 5 speed is auto, out of a 99 truck) or leave it in?
The 5.3l has the ls6 intake, updated fuel rails, and custom headers. Would all of these items swap over? both blocks are the same externally? Will the eaton fit in the transmission tunnel? will i grenade the stock differential with the 6 liter engine?
Old Sep 16, 2011 | 04:11 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: LM7 or LQ4
everything will swap over they are both great engines just one is alittle bit more power and tq your diff can hold depending on your driving I had over 200 passes with a 6 speed on my stocker and its still in the car It is a 4th gen rear though
wait you have a 67 it will hold try to find a 6 speed instead of the eaton from what I know eaton drivetrain parts are hard to come by
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Linson
Nov 12, 2015 08:09 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
iansane
Jul 22, 2009 01:49 PM
