1985 Z28 Advice
Old Sep 16, 2011 | 08:39 PM
Crazymadsnowman's Avatar
1985 Z28 Advice
Hello everyone! I am new to the site and this is my first thread. I have an 85 Z28. It's in great shape with only 56,000 miles. It has a 305 "H" motor in it. I am looking for some advise on some things I could do to get a little more HP. Like all of us I'm on a budget, but I am willing to invest some time and money. I'm not looking for high HP, just something a little more than what I have to make it a little more fun.
Old Sep 16, 2011 | 11:10 PM
torque_is_good's Avatar
Re: 1985 Z28 Advice
welcome
read stickies
use the search function
it's been asked/answered countless times over many years. They are called bolt ons and you'll find all kinds of opinions and suggestions.
Old Sep 17, 2011 | 06:46 AM
Re: 1985 Z28 Advice
Thanks for the response. I have been searching through threads and I think I'm gonna start with a new exhaust. Should I be worried about emissions testing? I'm not sure how far back they go for that. Maybe an intake after that?
Old Sep 17, 2011 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1985 Z28 Advice
Check state laws/regulations. Some states test, some don't.
JamesC
Old Sep 17, 2011 | 03:50 PM
Re: 1985 Z28 Advice
I checked into my state (ny) regulations. Since my car is over 25 years old it is exempt from emissions testing. Should I remove all emissions. Should I get a new catalytic converter with my new exhaust or just get rid of it.
Old Sep 17, 2011 | 08:25 PM
ex-x-fire's Avatar
Re: 1985 Z28 Advice
That HO has a carb right? I've seen guys grind the tab for the secondary barrels, so they open up 100%.
You can advance the timing to 10-12*, listen for spark knock.
Get a K&N air filter.
Old Sep 18, 2011 | 12:49 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: 1985 Z28 Advice
start with headers,factory headers are horrably restricting, and gut the cat.should free 25-40 hp same with tq
Old Sep 18, 2011 | 12:53 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: 1985 Z28 Advice
intake, blow-thru carb and a turbo set up!! run 1lb of boost if you only want alittle power
Old Sep 18, 2011 | 06:37 AM
JamesC's Avatar
Re: 1985 Z28 Advice
The stock HO exhaust manifolds, Y-pipe, and intermediate pipe were as good as if got--IIRC, there were no larger systems. You can purchase a direct-fit Catco high-flow cat. I've read that 5 hp is a common increase in power where after market cats are concerned. 25-40 would be very optimistic on an gutted OE system.
More info about exhaust manifold size and a pic of the HO (L69) Y-pipe in comparison with an LG4 Y:
https://www.thirdgen.org/forums/exha...-question.html
JamesC
greenyone
Sep 2, 2015 03:39 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Thornburg
Aug 26, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
