MAF ?
Old Sep 17, 2011 | 12:53 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
MAF ?
Is a 350tpi able to run without the maf senser hooked up at start up?My car didn't have it hooked up when I bought it.I hooked it up.(wires we chewed in two by mouse)While running,trying to find out some issues,I unhooked the maf conector and the engine died like now!
Old Sep 18, 2011 | 12:38 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: MAF ?
It should be able to. Unplugging the maf forces the computer into limp home mode and uses fixed tables, iirc, for the fuel. It should not only run it should be able to drive decently, considering.
I can't remember offhand the power flow through the relays so if one is fried it may kill something else, somewhere else. Sorry, it's been several years. Vader would probably still remember...
Old Sep 18, 2011 | 11:38 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: MAF ?
Why would it die when running and I disconected the maf sencer.Dose it have to be disconected before start up.I just dont want to mess somthing up.Red Devil-why havn't you picked up another 3rd gen.I see the others are tree hugers.
Old Sep 19, 2011 | 04:49 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: MAF ?
There is a delay before the ECM will set a code. Some calibrations have a default value for the airflow that allows the engine to idle, others dont. So, sometimes they will stall if you pull the plug while running.
Old Sep 20, 2011 | 12:58 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: MAF ?
Thanks,that helps me on future trouble shooting.I didn't know if it was just by chance or what.I didn't want to do it again to see if the same thing would happen.Might mess somthing up.Don't need to do that.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
