Trouble Starting
Old Sep 19, 2011 | 02:59 AM
wilkink's Avatar
Car: 1988 Pontiac GTA
Engine: L98 5.7L
Trouble Starting
First off, I would like to thank whoever can help because I haven't a clue what this could be.
1988 GTA
5.7 TPI
I have recently been having trouble starting the GTA and have no idea where to start. I filled up on premium the other day and since then, there seems to be an issue. It cranks and cranks but it won't start until you start pumping the gas pedal. Even right after it starts, you have to pump the pedal a tad until it finds its groove, which lasts about five seconds. I replaced the fuel filter and poured half a can of seafoam in the gas tank and half through the vacuum line. Still have the issue. Once I get the car started, after a couple pumps of the gas pedal, it runs fine and there are no issues. Forgot to add, it's not throwing any codes. I also just passed the emissions test with ease, so I have no idea where to start.
Old Sep 19, 2011 | 07:56 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Trouble Starting
first off dont ever pour seafoam in an old gas tank,you may have completely cloged the injectors with gunk.clean sensors iac tps things of that naturewhat ever the problem is it sounds like its in the uper intakein front of the tb
Old Sep 22, 2011 | 07:14 PM
wilkink's Avatar
Engine: L98 5.7L
Thanks buddy, I'll try it out tomorrow.
Old Sep 22, 2011 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Fuel pump priming when key turned on?
Old Sep 22, 2011 | 10:15 PM
wilkink's Avatar
Engine: L98 5.7L
Yeah, that was the first thing I checked when it happened. I thought it could be the fuel pump going bad, but when the car finally gets running, it runs and idles perfect. May try to clean the IAC and TPS tomorrow and see if that helps. Thanks for the response.
Old Oct 14, 2011 | 07:17 PM
wilkink's Avatar
Engine: L98 5.7L
Sorry for the extreme delay here, but I finally got around to getting some work done. I took apart the IAC and it was caked with dirt, so I cleaned that off and it is still starting like garbage. I checked the fuel pressure, and it is about 44ish. I guess we can cancel out the IAC, fuel filter, and since the car runs fine onces it starts, the fuel pump. I'm stumped, unless its the TPS, and I have no idea what I'm doing with that.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
