Spark on some plugs but not others
Old Sep 20, 2011 | 05:21 PM
Zimmerser's Avatar
Dunno what the probelm is, but I only have spark on some plugs and none on others. The spark is blue. I have checked the ignition coil and it is within specs. I replaced my iginition rotor, my distributor is rusty, and my tach works its way up while trying to start the car. could a rusty dist or tach be the problem?
Old Sep 20, 2011 | 05:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Spark on some plugs but not others
You've checked the cap, rotor and wires?
Old Sep 20, 2011 | 06:29 PM
Zimmerser's Avatar
How do I test the cap? I will go and swap the wires around to see if the spark changes. Rotor was replaced today.
Old Sep 20, 2011 | 06:51 PM
Zimmerser's Avatar
I moved the wires around and there is still good park so the wires are good. I even moved some of the spark plugs and checked the gaps...all good.
Old Sep 20, 2011 | 06:59 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Usually cap and rotor are replaced at the same time. The plugs not getting spark could be due to the cap. Try replacing that too. They are cheap enough.
Old Sep 20, 2011 | 08:03 PM
Zimmerser's Avatar
could a contributing factor be that the tach moving to 8k rpm while cranking?
Old Sep 20, 2011 | 08:31 PM
I have no idea if that would cause something like that to happen.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
