Smog/Air Pump
Car: 1991 Z28
Engine: 5.0L TPI
Transmission: 5 Speed
Smog/Air Pump
Have one question that maybe someone could answer. I have a noisy air pump that sound like a bad bearing that appeared right after I had the car transported down from S .Jersey and read an article in ThirdGen board that you can remove the pump from the car by rerouting the serpentine belt (“How to Remove Smog Pump Your Smog Pump From Your Serpentine Belt Equipped Third Gen” by Pablo Morales.) with a longer (96.8”) serpentine belt. Any comments or experience in this validity to that theory? Can it operate just as well or will be something take away from the equation? THANKS.
KEC
KEC
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Smog/Air Pump
It works fine - although you might need a slightly different length belt - seems like everyone needs a slightly different length than that write-up mentions - just have to experiment a bit - buy that size, one up, and one down, and then return the 2 you don't use.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Smog/Air Pump
The air pump is just an emissions device. As long as you don't need to have a visual inspection for emission testing then removing it is fine.
The purpose of the air pump is to put air into the exhaust system during engine warm up to reduce the emission levels of the rich exhaust. Once the engine is at operating temperature, the air pump does nothing.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
