Need help with my sons car...Please !!!
Old Sep 27, 2011 | 11:32 AM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
My son has my 1988 Formula 350 now but I live in Ontario Canada..(25 min, from Buffalo) and my son lives just outside Vancouver British Columbia Canada.
This is one weird problem that has us baffled.
The car will run okay for awhile then the tach will flutter or not work at times and then the car will start running on the battery...volt meter starts to drop to "0" and dies. Charge it up and its fine. The car may run fine for hours and then cuts out as above.
Had him check and replace the dist. cap (had a crack) and put a new OEM ignition module...had the alternator checked and was okay....had the battery checked and was okay. The car has 54,000 miles (86,000 km) on it.
Its very difficult to diagnose it over the phone.
Need all the help in this matter. My son will try all ideas but the last recourse would be to take it to the dealership which means throw parts at it philosophy as we all know.
Help in this matter would be greatly appreciated.
Bill
Old Sep 27, 2011 | 01:38 PM
Deluca119's Avatar
Re: Need help with my sons car...Please !!!
Im a kid as well, i had a somewhat similar situation but free things i would try is going over the grounds with a wire brush. Then checking the fusible links on the power block by the radiator.
Old Sep 27, 2011 | 02:25 PM
torque_is_good's Avatar
post #7 and # 10 seem like good suggestions in this thread
https://www.thirdgen.org/forums/elec...ge-issues.html
Old Sep 27, 2011 | 07:39 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Agreed, it's obviously either not charging, or if it is then the charge current isn't getting to the battery.
When the dash gauge starts to read low, get it running, get a multimeter and measure the volts at the batt terminals, then the alt terminal. See if they're different - shouldn't be of course.
If you've had the alt and batt tested ok, it's got to be a cable/terminal/ground problem.
Old Sep 27, 2011 | 07:56 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I agree. Clean every connection at battery, starter, alternator and ground.
Old Sep 28, 2011 | 03:09 AM
Transmission: 700R
Thanks for all the replies so far. I was suspecting grounds also but with your comments so far as where to look; it will help my son to sort it out as to where to look. Its very frustrating for me not to be there to help him due to distance.
Any other areas to look at ???? Its been 4 years since he has had the Formula and my mind is getting a little foggy to picture the detail areas . I did most of the work myself but its hard to diagnose problems like this unless you are there to personally see the areas in question.
Thanks again for all the replies so far.
Bill
Old Sep 28, 2011 | 07:31 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
I had a similar problem with my car. It was a bad negative Battery cable. Once I changed it my problem was solved try that
TX-SleeperC5
Feb 24, 2016 01:34 PM
darwinprice
17
Oct 11, 2015 11:51 PM
tattmann
Sep 27, 2015 05:20 PM
Ragtop Man
Sep 12, 2015 12:23 AM
scottmoyer
Sep 7, 2015 07:06 PM
