Sometimes when I go to start the car I will turn the key to start and it will just make a single click noise. Then I turn the key off and on and it will start just fine.
Is this the starter or starter solenoid...does this car have a separate solenoid? If so where is it at and does it sound like it needs to be replaced?
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,166 Times in 759 Posts
make sure your batt cables are clean and tight.
If its still acting up it could be the solenoid bad or starter switch/relay
Mine started doing that and I just swapped the whole starter out with a $49 reman. You can do the online coupon thing with some parts stores and get it even cheaper. Originally Posted by Shinobi'sZ
Sometimes when I go to start the car I will turn the key to start and it will just make a single click noise. Then I turn the key off and on and it will start just fine.Is this the starter or starter solenoid...does this car have a separate solenoid? If so where is it at and does it sound like it needs to be replaced?
The solenoid is on the starter and they are cheap if you want to go that route first, but the whole starter with a lifetime would probably be your best bet unless you find loose wires or something.
http://www.austinthirdgen.org/index.php?pid=38
In mine, the connector to the neutral safety switch won't stay fully connected, and a zip tie solved my issue. But you'll need to trace out your own gremlin.
