EECS Filter goes where?
Old Oct 1, 2011 | 02:10 PM
onemanrace's Avatar
Car: 1988 Camaro IROC-Z
After some poking about, I decided changing the filter in the EECS would be a good idea this weekend, mainly because I don't know when it was done last (not in the last 2 years certainly).
Looked up the procedure in the Haynes manual, which more or less says 'Undo the canister, turn it over, change the filter.' and not much else.
So that's what I did.
I'm stuck now though - I can't see any way of opening the canister to change the filter.
Perhaps I'm just too dumb. I dunno.
Can anyone shed some light on where this filter's meant to go?
Old Oct 1, 2011 | 04:27 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: EECS Filter goes where?
try giving the bottom a twist? if noone has an answer by the time i get home from work ill go out to the garage and figure it out. i dont care if it break mine trying since its not in the car anymore
FormulasOnly
Oct 2, 2015 05:52 PM
Linson
Oct 1, 2015 09:50 PM
