Distributor removal
Old Dec 11, 2011 | 07:51 AM
  #101
3rdGenMess's Avatar
Car: 1990 RS
Engine: SBC 350 YearOne Crate
Transmission: T56 (LT1)
Re: Distributor removal
Ok here's a picture of the plugs I pulled from the driver side of the engine block
Attached Thumbnails Distributor removal-2011-12-09_16-35
Old Dec 11, 2011 | 07:57 AM
  #102
3rdGenMess's Avatar
Car: 1990 RS
I know they are fuel fouled but what's the chances of being able to reuse a fuel fouled plug...I heard people say you can bake them to dry them out and clean off the electrodes...when I tried starting the car the first time after a month it tried and died. I ask because im still sceptical about spark plugs being my issue
Old Dec 11, 2011 | 12:24 PM
  #103
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Originally Posted by 3rdGenMess
Ok that link pretty much got me upset, why the hell would they put something that ain't worth a damn in a engine and put their name on it...now I'm not sure if I have a flat tap or not...but some one did mention the possibilty of the cam being in 2 peices but that's seems a bit extreme, but this could definately be my issue if I look at tdc on the other cylinders
A roller cam will raise the price of the engine by probably about another $1000.
You need to go in from the outset to make sure you get a roller engine. Retrofitting an older block to work with a roller cam costs a TON of money, about $1000 for all the parts. Running a flat tappet cam is about $200-$300 in comparison. A lot of guys do it, but you just have to be aware of what you have and you have to cater to its weaknesses and make sure it stays healthy.
When I do a cam swap this year I'm gonna put another flat tappet cam right back in it... why? Because $1000-$1300 for all the conversion parts is just too much for me to afford. My next engine I get will be a roller block from the start. That way you can just use the factory roller tappet hardware, and as long as you dont go too crazy on the cam, the factory stuff will work fine, and save you a crapton of money.
Its not that your cam is in two pieces, that's a bit ridiculous, honestly. Im sure it has happened at least once but jeez...
Here is another article about it:
http://www.stockcarracing.com/techar...n/viewall.html
Chances are if you're dealing with cam failure, you have one or more lobes that look like this:
Notice how the shiny one is rounded off more than the others? Its not nearly as tall? That translates directly into less valve movement.
If you cant get it to run on starter fluid (I would disconnect fuel for this too) then you need to stop and... Im not really sure how a compression test will help you, but you can definitely try a cranking vacuum test. Go to the auto parts store and buy a diagnostic vacuum gauge. They're at most $20. Run the main hose to any of the vacuum ports on the bottom of the carburetor (they should all be plugged, if they're unplugged then that may be part of why you cant get it to crank... I've forgotten the big brake booster port on the back of the carb numerous times) and then you just hit the starter and watch what the needle does. It will likely come with instructions taht tell you what to look for.
This is a video of it being done, very simple:
http://www.youtube.com/watch?v=FQEBFFn8Yms
Cranking Vacuum & Speed Tests
You can get a quick basic appraisal of engine condition by connecting a vacuum gauge to the manifold and a tachometer to the ignition to check vacuum and rpm at cranking speed. Warm up the engine first, then shut it down and connect your test equipment. Close the throttle and disable the ignition, or use a remote starter so the engine won't start. Crank the engine for 10 to 15 seconds and observe the vacuum and tach readings.
Note that different engines produce different cranking vacuum readings. Some carmakers publish specifications; others don't. Again, experience will be your best guide. What you're looking for, most importantly, is steady vacuum and cranking speed.
If the cranking speed is steady (about 200 rpm) and vacuum also is steady (around 5 inches), the engine most likely is in good mechanical condition. If rpm and vacuum are uneven, the cylinders aren't pumping equally. The engine probably has leakage past the valves, rings or head gasket. If the vacuum reading is pretty steady but cranking speed is not, you're probably looking at a damaged flywheel ring gear or starter. If the cranking speed is normal or high but vacuum is low and slightly uneven, the engine probably has low compression or retarded valve timing. A jumped timing chain or belt is a common cause here.
The cranking vacuum test also can provide a quick test for PCV restrictions. Perform the test and note the average vacuum reading. Then pinch the hose to the PCV valve closed with your pliers and repeat the test. If the PCV system is clear, vacuum should increase. If it doesn't, check the PCV system closer for restrictions.
http://www.atlanticz.ca/zclub/techtips/vacuum/
You know the engine is turning at a good speed by looking at it and listening to it, you dont need a handheld tachometer, so ignore that part of it. You also cant get the engine to run first to warm up, so the rings may not seal as well as they otherwise would, so if its a little lower dont panic. Otherwise just ignore that part of it also.
A vacuum gauge is a very useful tool and I think EVERYONE should have one. I dont see how a compression test will help you find a camshaft issue, but it will at least ensure you have good compression in every cylinder, but the cranking vacuum test will give you a (admittedly rough) idea of that too.
In your case with potentially bad cam lobe(s), you'd be looking for a fluctuation of vacuum in the cranking vacuum test. It will jump around and be lower than usual, it may even go to zero sporadically, depending on how its failing. If it pulls a steady, even 3-7 inches of cranking vacuum I think you can rule out cam failure preventing the car from starting. It should at least start. From there you could watch vacuum while the engine is running to get an idea of how healthy it is.
Vacuum Fluctuations & Power Balance
Several of the guidelines in this article have distinguished between steady vacuum gauge readings and fluctuating readings, where the gauge needle bounces up and down erratically. This may seem secondary-almost inconsequential-but it's an important distinction. A steady but abnormal vacuum reading indicates a problem common to all cylinders. Things like incorrect ignition timing or an old, tired, high-mileage engine affect vacuum equally for all cylinders. A bouncing needle, however, usually indicates that the problem is localized to one or just a few cylinders. Here's where power balance testing enters the picture.
Compression testing on many late-model engines is flatly impractical from a labor standpoint for a quick engine evaluation. That's especially true on some of the weird vans for which removing and reinstalling spark plugs is a two-hour job. It's relatively quick and easy, however, to connect a vacuum gauge to the manifold and your engine analyzer to the ignition system.
If your initial vacuum tests produce gauge fluctuations, you have a definite indication that the problem is limited to just one or a few cylinders. In these instances, a power balance test can help you pinpoint those cylinders and the condition they're in. Does the engine need a valve job (fluctuating vacuum) or a complete engine exchange due to universally worn rings and cylinders (steadily low vacuum)? Combine modern power balance testing with traditional vacuum analysis and you'll have the answer.
If your engine REALLy has a flat tappet cam, they would include very explicit instructions on how to break it in properly... 20 minutes at 2000 RPMs or something along those lines. If you didnt get ANYTHING to that effect with it, AND it had a flat tappet cam, I'd be pretty surprised.
Old Dec 11, 2011 | 01:56 PM
  #104
3rdGenMess's Avatar
Car: 1990 RS
This cause for celebration!!! It turned over and ran for the duration of the starter fluid!!!! It was the spark plugs...me being stubborn I didn't want to believe it but I guess they were really fouled beyond use so...thanks again guys appreciate the help!!!
Old Dec 16, 2011 | 02:03 PM
  #105
3rdGenMess's Avatar
Car: 1990 RS
Ok guys, I'm putting this thing back together. I need to know what's the best way about running the fuel back in the carburetor...should I hook out back the way it was before our should I adjust the fuel/air mixture screws all the way back in...I'm trying to avoid fouling these plugs again..and what's the fuel pressure for a typical carb...i wanna run my electrical pump again
Old Dec 16, 2011 | 02:15 PM
  #106
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you need 5-7 psi for the carb. you got a mech pump or return style regulator?
Old Dec 16, 2011 | 02:17 PM
  #107
3rdGenMess's Avatar
Car: 1990 RS
I have the mechanical pump still in...the only thing is, the fuel pump I have In my fuel cell only primes the fuel lines after that it shuts off and the mechanical takes over from there...
Old Dec 16, 2011 | 02:25 PM
  #108
travis401's Avatar
Car: 91 Camaro RS
the opsu should kick on the pump once it sees oil pressure. you can either use the intank electric with a return style regulator, or drop the tank and remove the pump, or run the electric with a mech pump IF the mech pump has a return line.
drawing fuel through a non working electric pump is gonna cause fuel starvation issues. itll start and run at idle for adjusting the carb though.
Old Dec 16, 2011 | 03:52 PM
  #109
3rdGenMess's Avatar
Car: 1990 RS
You said the oil pressure gauge will stop the fuel pump from operating? If I'm not mistaking the oil pressure guage plug is on the side of the engine bottom rear correct?
Old Dec 16, 2011 | 03:55 PM
  #110
travis401's Avatar
Car: 91 Camaro RS
no, the opsu is wired into the fuel pump as a fail safe. if the relay fails (or isnt triggered by the ecm) the opsu will send voltage to the fuel pump to make sure it runs when it senses enough oil pressure.
Old Dec 16, 2011 | 03:56 PM
  #111
travis401's Avatar
Car: 91 Camaro RS
as long as you havent cut any wires from the fuel pump or opsu, itll run when the oil pressure gets high enough. usually about 3-4 revolutions.
Old Dec 16, 2011 | 05:00 PM
  #112
3rdGenMess's Avatar
Car: 1990 RS
Well the way it was operating was find so I think ima try and get it running just like it was....turn on to prime and then let the mechanical take over...the mechanical has the return line so it should shoot the extra fuel back to the tank if it primes unnecessarily
Old Dec 16, 2011 | 05:10 PM
  #113
travis401's Avatar
Car: 91 Camaro RS
if the opsu is operational, and still wired into the fuel pump, itll kick on the electric pump. if not then youll need to either wire the fuel pump relay trigger wire into a switch 12v source, or drop the tank and pull it.
Old Dec 16, 2011 | 06:02 PM
  #114
3rdGenMess's Avatar
Car: 1990 RS
Oh ok so everything is good I jus think the whole fuel pump assembly is not exactly like the original but that's fine...it worked before the engine issue, no fuel starve or nothing so ill jus cont. The way it is until its time to perfect the craft...until then I jus want to enjoy it for a change
Old Dec 17, 2011 | 01:37 PM
  #115
3rdGenMess's Avatar
Car: 1990 RS
Ok jus tried starting the car on fuel and no luck...smh I'm thinking this may be the cause of all my heart ache...starter fluid sparks and ignites the engine but the fuel doesn't do anything, is there such thing as bad fuel, and if so, what's the quickest way to diagnose and get it out???
Old Dec 17, 2011 | 01:59 PM
  #116
travis401's Avatar
Car: 91 Camaro RS
yea. fuel can degrade to the point of not being combustable enough. take a small bit and see how well it burns. are you sure youre getting fuel to the cylinders?
Old Dec 17, 2011 | 02:07 PM
  #117
3rdGenMess's Avatar
Car: 1990 RS
Well the fuel is flowing from the tank to the carb fine...when I took the carb off and pulled the throttle linkage fuel fell from the bottom and when I used the starter fluid the car actually started for the duration of the starter fluid so id assume its falling thru intake just fine as well...
Old Dec 17, 2011 | 02:45 PM
  #118
travis401's Avatar
Car: 91 Camaro RS
if itll run on starter fluid its either not getting fuel to the cylinders or the fuel isnt combustable enough. you can test this easily since you have a mech pump.
take the feed line on the mech pump and run it into a container with fresh gas in it. just be sure to pull the fuel pump fuse so the electric pump doesnt try and prime and shoot gas everywhere. if it starts that way then you have bad gas.
Old Dec 17, 2011 | 02:48 PM
  #119
3rdGenMess's Avatar
Car: 1990 RS
Awww man I didn't even think to try that! So I take it I should clean all that old fuel from the carb first
Old Dec 17, 2011 | 02:50 PM
  #120
travis401's Avatar
Car: 91 Camaro RS
just drain the primary bowl. itll take a few cranks before the mech pump fills the bowl enough to start once you drain it.
Old Dec 17, 2011 | 02:55 PM
  #121
3rdGenMess's Avatar
Car: 1990 RS
What about my secondary? Will draining the primary cause the secondary to empty as well or will I have to remove the carb
Old Dec 17, 2011 | 02:59 PM
  #122
travis401's Avatar
Car: 91 Camaro RS
secondaries are only used under hard acceleration under load. they wont open while idling and therfor wont dump any gas into the engine. primary is all you need to drain to test the gas.
Old Dec 17, 2011 | 03:13 PM
  #123
3rdGenMess's Avatar
Car: 1990 RS
Sounds good! Ima get on it once I take this 30 min commercial break to assist my wife "booo".
Old Dec 17, 2011 | 07:07 PM
  #124
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Just how old is the fuel? I chased a no start for 3 frustrating days until I realized the fuel was just too old for my combo it run on. After draining all the old crap out and putting 5 gallons of 93 + 5 gal of cam 2 racing fuel it started right up and ran a tad crappy for a few min and totaly cleared up after 5 mins of idleing. If that tends to be your case replace your fuel filter also. Should be able to tell by looking at some of it in a clear glass bottle, bad gas normally appears quite yellow and smelly compaired to the also clear color of fress fuel. May even be worth it to just drain what you have put some new fuel in along wiht a filter so it at least know you're running clean fuel. Good luck, and as suggested disable fuel, drain primary fuel bowl and try to start/run it by spraying starting fluid and keep it running for a lil bit. If that works out, reinable fuel system if you sure you have good fuel and see if it starts, keep us updated
Old Dec 17, 2011 | 07:28 PM
  #125
3rdGenMess's Avatar
Car: 1990 RS
Yea I pulled the primary drained it got some fresh fuel...I'm glad you described the bad fuel and how it looked...that fuel was gold, I'm running some fresh fuel now 93 octane...it starts fine with the starter fluid, but I guess the carb was so contaminated with the bad stuff that its still not working...is there a way to like flush the carb??? I need to flush the tank as well but just wanna know for certain that the bad fuel is the case
Old Dec 17, 2011 | 07:33 PM
  #126
travis401's Avatar
Car: 91 Camaro RS
youd have to pull the carb off, take it apart and soak it in carb cleaner to clean out all the passages. which if its an older carb it could probably use a freshening up. rebuild kits are normally around $25
Old Dec 17, 2011 | 07:35 PM
  #127
travis401's Avatar
Car: 91 Camaro RS
you can soak it in carb cleaner, a degreaser, paint thinner, or a number of other solvents.
Old Dec 18, 2011 | 02:01 PM
  #128
3rdGenMess's Avatar
Car: 1990 RS
Ok I think my issue lays in my spark...obviously I have spark because I can start on starter fluid...do anybody know anyway to increase the power of the spark? I charged my battery over night, got a new ignition coil, new plugs, new wires, (i had accel wires at first and seen cracks in them, didn't buy accel this time, should I have?) My distributor cap seems to be operational, no cracks..I did notice some white substance under the ECM (the black orange slice plastic peice) I don't think that's supposed to be there idk ill take pictures of my findings later...
Old Dec 19, 2011 | 01:16 PM
  #129
4FishLimit's Avatar
Car: 1986 Trans Am
Engine: LB9
Transmission: TH700R4
Axle/Gears: 2.73 & LSD
You have it backwards.
Your engine runs on starting fluid, but dies when you stop feeding it starting fluid, meaning it's not getting enough fuel to stay running. Considering you have replaced nearly every component in your ignition system, I would suspect it is no longer suspect.
Change your fuel filter, including the filter inside the carb as well (assuming you're not just running an inline filter).
Old Dec 19, 2011 | 01:33 PM
  #130
3rdGenMess's Avatar
Car: 1990 RS
I see what your saying...but my bowls fill up just fine front and back...I pull the throttle linkage four times and it sputtered and continue to turn but no start...I jus find it hard to believe that I would have to pump the accelerator or press the throttle link that many times if the spark was strong enough.
Old Dec 19, 2011 | 01:38 PM
  #131
travis401's Avatar
Car: 91 Camaro RS
if it runs on starting fluid then its getting a good enough spark. either your gas is too bad to run it, or youre not getting gas in the cylinders.
Old Dec 19, 2011 | 03:16 PM
  #132
Car: 1992 Camaro RS
What carburetor do you have? Do you know how to baseline a carburetor?
Starting an untuned carbureted car can be a little bit of a tricky game. It's not difficult, but if you give it too much of a pump shot at first it can flood, if you dont give it enough it will sputter. You'll Have to play with the throttle while it's turning over to get it right. Is there a choke? That may or may not be complicating things for the moment. I'd probably leave it completely open and just hold the engine at speed using the throttle.
Your issue is fuel delivery. If it runs on starter fluid it has spark. You know your carb is getting fuel, you know you are getting spark. The problem lies in the fuel getting from the bowls to the engine.
This is for a Holley, will not apply to an Edelbrock or Qjet:
http://hotrodscott.blogspot.com/2007...ingtuning.html
Pay attention to steps 2, 5, and 8. In fact you may be well served by upping the idle speed a good bit just to make it easier to get it running and keep it rnning. You can properly set the idle later.
If it's a holley you can set the floats with the carb off the car by removing the fuel bowls and turning it upside down and just adjusting it so that the float is horizontal. After you get the car running, you can more accurately set it.
Old Dec 19, 2011 | 04:13 PM
  #133
3rdGenMess's Avatar
Car: 1990 RS
I was reading the link good info...but some of it was completely unclear as far as the jetting part but correct me if I'm wrong, so the best way to get it running is to adjust the idle screw so that it idles high so that fuel will fall into the intake
Old Dec 20, 2011 | 08:49 AM
  #134
Car: 1992 Camaro RS
To be clear, you cannot expect a cold engine to run just fine without you physically holding the throttle open to keep it running. I dont know how the choke is set up, whether it's there or not, or what carb you have.
You need to play with the throttle til it fires up and hold it open enough to keep it running. There's no ECM constantly adjusting based on its sensors to make it run nicely when its cold and grumpy.
Get it running and then adjust the curb idle screw so that you dont ahve to hold it open anymore.
The jetting and whatnot isnt an issue right now. It should still fire up. You play with jetting after you get the car idling and running and the timing set. Just driving the car around in various ways will tell you about jetting, what that doesnt tell you can be understood by reading plugs, but you can get close without ever pulling a plug.
Is it a Holley double pumper? If so there's an excellent sticky on tuning those on the carb board.
https://www.thirdgen.org/forums/carb...ey-tuning.html
Old Dec 20, 2011 | 10:34 AM
  #135
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
This is awsome.... Its a freakin carb. There are only a very few posible things that can be wrong...If you can keep it running with starter fluid the timing is right and you got a fuel problem. Holy crap. Its got a holley on it not fuel injection the damn thing isnt going to start and purr like a kitten at the touch of the key. Where do you live so i can come fix this thing.
Old Dec 20, 2011 | 11:12 AM
  #136
3rdGenMess's Avatar
Car: 1990 RS
Lmao dude calm down! I already stated before I don't know shyt bout the technicalities of carb or the engine...I'm still trying to fugure out what a jet is...I know it needs fuel, spark, combustion and air. If you in killeen feel free to come work your magic hell all my time to fix it has elasped I'm about to leave and have to move it to storage
Old Dec 20, 2011 | 09:32 PM
  #137
3rdGenMess's Avatar
Car: 1990 RS
Well the damn thang ain't purrrin like a dog neither...and your right it is simple but the damn thing won't start...I can't think of nothing else except to rid myself the head ache of this good foresaken holley
Old Dec 20, 2011 | 11:00 PM
  #138
89RsPower!'s Avatar
If it will start and run on starting fluid the only thing left is a fuel issue. How old is the gas in the car? If it ran fine before siphon the old stuff out of the tank, replace the fuel filter, grab a gas can and get a couple gallons of super, put the fresh gas in the tank and spray a little starting fluid down the carb and crank it. If it starts keep ur foot on the gas pedal and try to hold it at a high idle (2kish) for a few min until it will idle by itself, may take a bit to clear the crap out. Until you know you have fresh fuel don't attempt to adjust the carb, timing, or anything else before replacing the gas or you will simply make more problems to fix..
Old Dec 20, 2011 | 11:09 PM
  #139
3rdGenMess's Avatar
Car: 1990 RS
I've tried it already...I have a fuel can sitting under the hood and have my mechanical pump sucking from the fuel can of top grade pump fuel...it won't start...it starts on starter fluid when I spray it in each of the 4 barrels of the carb...but when I pull the throttle assembly on the carb, fuel is squirting into the barrel and also the butterflies are opening to the intake...it only fires on starting fluid and won't do nothing but turn over on fuel
Old Dec 20, 2011 | 11:14 PM
  #140
3rdGenMess's Avatar
Car: 1990 RS
it fires on starting fluid, it doesn't run...cause its only me and I'm not over spraying starter fluid in an engine jus sounds like grounds for self destruction...I spray moderate amount go to the ignition, attempt to start and it ignites and dies off...try again with the new fuel...no start just turns over...
Old Dec 20, 2011 | 11:41 PM
  #141
travis401's Avatar
Car: 91 Camaro RS
id pull the carb off an do a complete rebuild on it. if it runs on starting fluid then its a fuel delivery problem with the carb. it could be a blocked passage or something preventing adequate fuel in for combustion.
Old Jan 1, 2012 | 08:07 PM
  #142
3rdGenMess's Avatar
Car: 1990 RS
Well gentlemen it was bad fuel...took forever to realize that but now I know for future references...I'm jus waiting on a rebuild kit for my carb...I hope this works...there's a crack on I think its the idle valve smh...damn carb cleaner is destroying my carburetor..who ever thought of this stuff was obviously in cohoonce with carb makers
Old Jan 1, 2012 | 08:27 PM
  #143
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Originally Posted by Apeiron
You couldn't even get the engine out without removing the distributor first anyway.
untrue, I did it 4 days ago with the cap and wires still on, was not an issue at all (I do run a remote coil). Transmission was disconnected and slid back then the motor was pulled up and out with an engine hoist
Old Jan 7, 2012 | 07:06 PM
  #144
3rdGenMess's Avatar
Car: 1990 RS
I'm back! Bad fuel wasn't the issue...still confused... did notice something when I called a mobile. Mechanic over...when he was trying to start her up, there was gas under the car coming out the headers...he said it was the choke, once I replace it ill be good to go, I definitely disagree, a bad choke can't possibly cause fuel to run out the exhaust...I know the valves can't be out of sync...because it started on the starting fluid fine like its been running all year. I'm all clued out???? The mechanic also said when and if it starts again...it will be an extremely loud backfire, I jus want to know what the hell is wrong with the POS so I can know wether to store it or trash it.
Old Jan 7, 2012 | 07:20 PM
  #145
travis401's Avatar
Car: 91 Camaro RS
if you have fuel pouring out of the exhaust, you either have a) too much fuel going in for combustion and just getting forced out of the exhause valve or b) bad gas thats unable to combust.
it runs on starting fluid with the gas source cut off. so we know its not timing, spark, or airflow problems. that only leaves the gas/gas delivery method.
honestly at this point id swap the carb out to a different one. it sounds like it could be the issue. got a buddy with a carbed car you can borrow from? (its a carbed engine right? i cant remember)
Old Jan 7, 2012 | 07:28 PM
  #146
3rdGenMess's Avatar
Car: 1990 RS
Yea its carbed...where is he located???
Old Jan 7, 2012 | 07:40 PM
  #147
travis401's Avatar
Car: 91 Camaro RS
no no no, i was asking if you had someone you could borrow a carb from to test.
Old Jan 7, 2012 | 07:47 PM
  #148
3rdGenMess's Avatar
Car: 1990 RS
Lol oh no...I'm the only one I know that ventures further then changing tires...I really would like to get. The understanding of this one first before I venture to sometihng different...I know all carbs are generally the same..if so, if another one works then why doesn't mine
Old Jan 7, 2012 | 07:54 PM
  #149
travis401's Avatar
Car: 91 Camaro RS
could be that its either damaged in some way, or needs a rebuild. if its just dumping fuel into the chambers so much that its pouring out of the exhaust, i would suggest replacing it for a test to make sure its the cause of the no start before replacing it perm or spending money on a rebuild for it.
Old Jan 7, 2012 | 08:05 PM
  #150
3rdGenMess's Avatar
Car: 1990 RS
Would this be a good assumption if I say the vacuum is at operating level if its sucking the starter fluid down the cylinders? My uncle told me to put racing fuel in it??? It makes sense but doesn't explain why it worked before the flooding and not after. I'm starting to believe 1 of 2 things...1) the rings been worn so that compression is too low...or 2) the spark is only strong enough to ignite extremely flamable liquids
