EGR valve sensor, how necessary?
Old Oct 5, 2011 | 03:30 PM
Z28NZ's Avatar
Car: 85 Z28
Engine: 355 Vortec TPI
Axle/Gears: Stock
Hi all, am currently getting rid of extraneous pollution gear off my LB9 engine, AIR, Cat and fitting headers, (yes will fit heated O2 sensor) I would also like to remove the EGR setup and from my research it seems I can do this provided I leave the solenoid intact so the computer thinks its still doing it job (obviously vacuum lines will be sorted out). What I would like to know is; what is the sensor that screws into the cast base of the EGR valve and can I do away with it so I can completely blank off the ports where the EGR valve sits?
Cheers Simon
db057
Sep 4, 2015 07:57 AM
Out-Cast
Sep 3, 2015 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Out-Cast
Aug 17, 2015 10:57 AM
