cam change
Old Oct 5, 2011 | 09:49 PM
hillbilly Z28's Avatar
Car: 1985 Z28
cam change
got a summit 1103 cam 272 282 how well will this work in my stock 305
Old Oct 6, 2011 | 01:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cam change
What kind of stock 305?
Old Oct 6, 2011 | 05:48 PM
Car: 1985 Z28
Re: cam change
factory 305 was tpi but got rid of that and went to carb.
Old Oct 6, 2011 | 05:49 PM
Car: 1985 Z28
Re: cam change
also have a set of 350 stock heads but do not know if they will work on my 305
Old Oct 6, 2011 | 08:38 PM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
Re: cam change
are the heads 194 intake and you need to come to cruz in last one this year at old champmanville high on 3rd sat this month at 5pm you know where jeffrey is ? i kinda live over there
Old Oct 6, 2011 | 08:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: cam change
Thats a lazy old school cam. Much better modern grinds available.
I'd go with a comp xe256 in a 305 with 081/416 heads and 9.0:1ish compression.
Old Oct 7, 2011 | 06:25 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: cam change
I had two of those 1103's (or the Crane/GM equivalent) in my 350, before I got wise. Swapped to an XE262, no other changes. Straight away much more pull across the whole rpm range, much better throttle response.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
