Unknown Sensor?
Old Oct 6, 2011 | 07:13 PM
rfcomp's Avatar
Car: 1990 Camaro RS
Unknown Sensor?
Just wondering if anyone can identify the sensor in the attached picture at least I think its a sensor or part of one. This is on the passenger side, any help would be appreciated.
Old Oct 6, 2011 | 07:48 PM
ex-x-fire's Avatar
Re: Unknown Sensor?
Coolant temp sensor? Is the rest of it still in the head between the spark plugs?
Old Oct 6, 2011 | 07:56 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Unknown Sensor?
Is it a bulb socket for an underhood light?
rfcomp's Avatar
Car: 1990 Camaro RS
Re: Unknown Sensor?
Yes there is part of a sensor between the spark plugs but I thought the coolant temp sensor had the same connector as the knock sensor. And I do have 2 of those connectors unplugged right now. If it is the coolant temp sensor then what do I hook up the second unused connector to, the one that looks like the knock connector?
Old Oct 6, 2011 | 10:22 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: Unknown Sensor?
Year, make and model, please.
Maybe the cooling fan switch came apart (located between cylinders 6 and 8, I think) at the top of the head. The knock sensor is towards the bottom of the cylinder head passenger side. Someone may have wired a different connector for a "colder" sensor. How many wires are coming out of it?
Hope this helps.
Old Oct 7, 2011 | 07:16 AM
rfcomp's Avatar
Car: 1990 Camaro RS
Re: Unknown Sensor?
Its a 1990 RS 305 TBI. This has a 2 wire connector.
Old Oct 7, 2011 | 02:27 PM
1killerolds's Avatar
Re: Unknown Sensor?
what color are the wires? it looks like a coolant temp or manifold air temp sensor. the sensor that has the same connector as the knock sensor is the fan switch, they are both single wire connectors. temp sensors use two wires. My guess is the manifold air temp or intake air temp sensor with the tip broken off. Wire color will help.
Old Oct 7, 2011 | 06:58 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Unknown Sensor?
Two wires and gray body points to IAT. TBI cars used a remote sensor in the air cleaner which breaks off if a careless person removes it
Old Oct 11, 2011 | 07:35 PM
89BadRS's Avatar
Car: 89 Iroc
Engine: 5.7 Tpi
Transmission: WC T5
Axle/Gears: 9 bolt/stock
Re: Unknown Sensor?
I'm having idle problems and surging and I have been replacing sensors one at a time and that is one of my next ones.....like Pocket said that is in the air cleaner I have a 91 RS TBI 305.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
