Rocker arm question
Old Oct 9, 2011 | 09:07 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Rocker arm question
I'm rebuilding my 350 and I had a question about rocker arms. I want roller tipped rockers like these http://www.jegs.com/p/JEGS-Performan...31437/10002/-1 but can I just bolt those in and can I have 1.6 ratio rockers with the stock cam and springs?
Old Oct 9, 2011 | 10:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Rocker arm question
Might be better off stepping up to the comp magnums for a little more. Theyre stronger and more consistant than the stamped steel ones. Those ones from jegs wont be much better than what you have stock.
What engine are you working with? Stock L98?
Old Oct 10, 2011 | 11:03 AM
Its a Goodwrench 350 crate don't know much about it. What about 1.6 ratio rockers?
Old Oct 10, 2011 | 11:24 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
1.6 on a stock cam will be fine. if your already rebuilding the motor, id spend the money on a cam first,..if your trying to achieve more lift & duration from the 1.6s? more power for the money. on the rockers, id save for some full rollers or look for some good used ones. JMO.
Old Oct 10, 2011 | 11:35 AM
torque_is_good's Avatar
When I think "rebuild" I envision the engine torn down completely.
Is that your definition as well? if so, then since the cam is already out and new bearings being installed, why re-use the old cam?
If you want performance, while the heads are torn down and being worked, why re-use the stock springs?
But, if your definition of rebuild is different, please explain what is really being done and we can go from there.
Old Oct 10, 2011 | 12:36 PM
I was planning on putting this cam in http://www.summitracing.com/parts/SUM-K1102/ would the 1.6's work with it?
Old Oct 10, 2011 | 12:37 PM
As far as heads, are these any good? http://desmoines.craigslist.org/pts/2629347969.html
Old Oct 10, 2011 | 12:38 PM
http://desmoines.craigslist.org/pts/2637944408.html Also found these.
Old Oct 10, 2011 | 12:40 PM
Oh and as far as the rebuild its been bored .30 over http://www.summitracing.com/parts/SUM-SBCKIT1-300/ and this has been put in
Old Oct 10, 2011 | 02:37 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
looks like a good deal on the rockers. those heads are 58cc. with your flat-tops, those 58cc heads will most likely not like pump gas. id stick with 64cc heads. that cam is barely over stock. id try the k1103 or k1104 for a mild build.
Old Oct 10, 2011 | 05:22 PM
I wanna keep it streetable you could say so I was looking for a low rpm range cam. All of this will work with TPI right?
Old Oct 11, 2011 | 05:30 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
my fault. i thought you had a carb motor for some unknown reason. duhho! tpi is touchy to changes in cams. now i see why you wanted to use 1.6s on a stock cam. most tpi motors use self-aligning rockers. changes in compression may warrant a computer/chip tune, possible larger injecters, more fuel pressure, etc. IF, you need computer/chip work, may as well see if you can get away with a little more cam.
Old Oct 11, 2011 | 11:39 AM
so will those rockers work with my heads I have currently?
Old Oct 13, 2011 | 10:00 PM
Will full roller rockers work with my heads? they're 369 casting heads
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
