What could this be?
Old Oct 11, 2011 | 10:01 AM
Turk's Avatar
What could this be?
EDIT: i didn't know where this question really fit in so please forgive if you feel it belongs in another forum.
EDIT: after a quick smoke break and some hard visualization/thinking i believe it to be the heatshield. Any thoughts?
89 formula 350
This morning i noticed something hanging under the car. I was in a rush to go to work but i couldn't tell if it was plastic or metal. I was driving it just fine and i suspect its just some type of splash guard?? but it is hanging right behind the bend of the y pipe and is almost like a cirular/conish shape and ideas anyone? its very thin so either sheet metal or plastic and has a big hole in it.
On good news. I had a bent axle in my 9 bolt and swapped out with a rearend from a 95 with 373 and she is running like a champ again. B&M megashifter going in some time this week.
i also heard a wierd sound but i suspect it is just what ever is hanging vibrating due to the fact my exhaust is currently removed after the y pipe.
any help on identifying what this may be will be greatly appreciated if no one knows time to bust out the jack.
Old Oct 11, 2011 | 11:55 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: What could this be?
Could be the outer shell of your catalytic converter, maybe...
Old Oct 11, 2011 | 01:49 PM
Turk's Avatar
That would be a possibility but when i had the car the y pipe was cracked about an inch long and was hanging a little, so i ripped off the whole exhaust from that crack back. So that would be ruled out. I probably should of mentioned that in the original posting my bad! sorry!
Old Oct 12, 2011 | 06:49 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
ah, ok...
well, I have seen a 3rd gen or two with a shell above the cat, sort of pinned to the floorboards...
Maybe that's it...
Old Oct 12, 2011 | 12:08 PM
Turk's Avatar
ah, ok...
Maybe that's it...
That's what i thought but it wasn't the case. It was some sort of dust cover over the torque converter and what not.
