any one elsahave this problem with exhaust manifold?
Old Oct 13, 2011 | 08:36 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
hey to all im doing a build on my motor and includes taking of the heads and in order to do that need to take off my exhaust manifolds (correct me if im wrong) got the driver side of it with ease but the passenger size is so crowded
i have to bolts left cant get to em wat so ever
the last bolt closes to the fire wall
and the bolt that holds the dipstick in place
its a 92 firebird
the heater box thing is in the way
also the bolt that holds the oil dipstick has a bolt under that metal plate cant get to it
thanks to all for this help
also one last question leaving the driver side head open (where exhaust manifolds meet head) during the rain good hoods closed ofcourse but should i be concerned about moisture or condensation
(i problly should time to cover it up)
Old Oct 14, 2011 | 01:49 AM
dabird07's Avatar
Car: 92 firebird
Re: any one elsahave this problem with exhaust manifold?
bump by the way air pipes or w/e called the bolts are stripped might kjust cut em off
Old Oct 15, 2011 | 10:40 PM
dabird07's Avatar
Car: 92 firebird
ok one bolt to go cannot get top it anyones advice???? bolt closes to fire wall
bolts to air tubes are stripped might need em to be cut off
Old Oct 15, 2011 | 11:48 PM
WilliamSilver's Avatar
tried getting it From the bottom, with a swivel socket?
Old Oct 16, 2011 | 01:12 PM
dabird07's Avatar
Car: 92 firebird
dang heat coil boxz is in the way it needs a extensionj but the one i have is to long ant it want fit from bolt to heater box
i tried to take out the heater coil box but at the bottom there two i dont even know wat to call it it seems like theres two bolts to holkd it in from the inside as well
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
theurge
Aug 21, 2015 12:46 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
