high idle issue
Old Oct 14, 2011 | 12:47 AM
wranglaro86's Avatar
Car: 1986 camaro z28
Engine: gm goodwrench 350 300 hp
Transmission: 5sp
Axle/Gears: stock
high idle issue
can a bad alternator cause the car to idle high? 1986 z28
Old Oct 14, 2011 | 01:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: high idle issue
If it's carbureted.
Old Oct 14, 2011 | 11:57 AM
Transmission: 5sp
Axle/Gears: stock
Re: high idle issue
yes it is carbureted. Apeiron do you think you can explain a little bit about it for me?
thanks! my alternator is shot only putting out 2.5 volts currently ordering a new one.
Old Oct 14, 2011 | 12:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: high idle issue
No alternator means no charge sense. No charge sense means no choke power. No choke power means no choke opening. No choke opening means pig rich and fast idle.
Old Oct 14, 2011 | 12:46 PM
Transmission: 5sp
Axle/Gears: stock
Re: high idle issue
thanks a lot for your reply. i will reply after new alternator comes in thanks!
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
