my 89 wont stay running on its own
Old Oct 15, 2011 | 04:57 PM
TBZEKE's Avatar
Car: 89 IROC Z
Transmission: 5 speed
ive drained old gas and replaced with 93.i installed new fuel pump filter and injectors...plugs and wires look to be good or should i change them? it starts with starting fluid but i have to play with the gas pedal to keep it running but once i let off it dies out instantly...ANY IDEAS OUT THERE? and my rpm needle stay up wen it does start
Old Oct 15, 2011 | 06:15 PM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
Re: my 89 wont stay running on its own
What do you mean that the rpm needle stays up when it starts? Is your check engine light on? How long has the car been sitting?
Old Oct 15, 2011 | 06:54 PM
TBZEKE's Avatar
Car: 89 IROC Z
......wen i turn the key to start it jumps to 7 and then do what it want to do till it cut/turn off..it was sitting for about 8yrs..and yes my check engine light is on
Fronzizzle
Mar 18, 2019 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
Sherpajames
Aug 7, 2015 06:56 PM
