Need help feeding gauge wires through firew
Old Oct 19, 2011 | 08:14 AM
trevorsmith82's Avatar
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
Im installing a gauge pod for my firebird while i change the head gasket, problem is I dont know where i should feed everything through my dash through to fire wall to the block pictures or anything will be gratefully appreciated
Thank you
Old Oct 19, 2011 | 02:07 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
Re: Need help feeding gauge wires through firew
Im not sure how similar firebirds are but on my camaro there was a hole for wires behind the steering column. i would pull the panel to expose the whole thing and there should be wires going into the fire wall and you can always add holes
Old Oct 19, 2011 | 03:00 PM
Thanks man ill take a look at it once this weathers clears down here, which panel exactly you were talking about, before I go in there?
Old Oct 23, 2011 | 10:10 PM
Engine: 5.0L 305
there should be a panel that comes off it has a door to pop on to get to the fuses at least on thats how it set up on camaro but ill try to upload a picture of it
Old Oct 24, 2011 | 05:51 PM
Sorry for a late response, I actually took most of my dash apart the other day and it turns out ill most likely be needing to drill a whole for the wires and etc maybe there is a whole some where im just not gettin a good view of it from either side of the firewall
Old Oct 25, 2011 | 11:24 PM
Engine: 5.0L 305
keep me updated on that i think maybe someday after i drop a bigger engine in mine i may do guages to replace the old ones
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
