Help Me Decide On a Cam
Old Oct 22, 2011 | 01:54 PM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
I'm building a 350 for my car and can't decide on a cam. I already have a 260xfi from a previous build that never happened (I was going to sell it, but now I'm wondering if I should just use it). However, I keep looking at the 268xfi. I know a lot of people run the 268xfi, but I'm not sure if it would be "the right cam" for me so I keep flip flopping between the two (or should I look at something else?).
The car is going to be used as a daily driver so gas mileage is obviously a concern. I do want this car to be fun though. I really don't see myself doing a cam swap once the engine is in the car, so I want to get it right the first time. I'm really hoping for around 350fwhp.
The engine is just a stock shortblock 350 bored .060 over with full dish pistons (12cc). The heads are 195cc, no name brand (Renegade I think?) vortec style aluminum heads with 64cc chambers and 2.02/1.6 valves.
The flow numbers that were given to me for the heads are:
Lift Int Ex
.200 114.3 92.7
.300 163.3 124.0
.400 207.7 150.4
.500 243.2 171.0
.600 265.8 173.6
Compression should be around 9.3:1 (piston to deck clearance is ridiculous on this thing). I will be running 1.6 roller rockers and fueling will be via TBI (50mm bores, 90lbs injectors, afpr). I haven't decided for sure on the intake. I have a GMPP TBI intake which I will probably use if I go for the smaller cam. I might go for a Performer RPM manifold with adapter if I go bigger on the cam.
I'm also going to go with a 2000 stall converter (depending on the cam, maybe a 2500) and I will be swapping the rear out with 3.42s.
Opinions?
Old Oct 22, 2011 | 04:28 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Help Me Decide On a Cam
Definitely stick with the smaller cam for that low compression and the mild torque converter options you're considering.
Old Oct 22, 2011 | 05:10 PM
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
Kinda what I was thinking. It's just hard to fight that itch for bigger. Think I should still be able to hit my horespower goal of 350fwhp? Any other thoughts?
Old Oct 22, 2011 | 06:55 PM
86LG4Bird's Avatar
Probably not 350 fwhp. But... attempting to get there by going with a mismatched cam will only result in an all-around lower performing engine, less average hp in the useable rpm range.
Old Oct 22, 2011 | 07:19 PM
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
Hmm...good point. Any ideas how to get to my goal? I could get the block decked to raise the compression (should move it up around 9.7) but I don't know if it would be worth the cost/trouble considering what's in the bottom end. I'm trying to get this thing finished within a month too.
Old Oct 22, 2011 | 07:21 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
what about useing a 0.015 compressed head gasket?
Old Oct 22, 2011 | 07:46 PM
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
That's what I was planning on using. The piston to deck clearance is ridiculous on this block. Like .045". I checked it using a straight edge and feeler gauges. So with a .015" gasket that's still .060"!
Old Oct 24, 2011 | 08:34 AM
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
I'm probably asking the wrong question. I should be asking what would I be happiest with given the combination and intended purpose (daily driver). Should I just slap together what I have? Should I pay to get the deck blocked and run the 260xfi? Or should I have it blocked and run the 268xfi? I'm not trying to spend a ton of $$$ on this thing but is a .4 increase in compresson (from 9.3 to 9.7) really going to make a big difference?
camaro71633
Sep 1, 2015 10:24 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
neekolzun
Aug 24, 2015 04:59 PM
BurlyChev
Aug 16, 2015 09:08 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
