The mysterious knocking noise...
Old Oct 24, 2011 | 05:08 PM
Camaro_91_00's Avatar
Car: Camaro!
Engine: 305... soon to be a 350
So... I have a 91 RS Camaro. The odometer reads 135,000 miles but I replaced the motor with a rebuild one my boyfriend picked up as a birthday present. All the guy said was that it came out of a camaro similar to mine, was rebuild about 5,000 miles ago, and ran fine when pulled. But once i got this motor in it and started it, it was making this mysterious knock.
I've attached a video link... watch it all the way through, the sond changes as the car warms up. Thanks, any help would be appreciated.
[[P.S, we put in new oil, tranny fluid, coolant, etc. before starting the motor.And excuse my loud friends in the background]]
Mystery Knock
Old Oct 24, 2011 | 05:56 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: The mysterious knocking noise...
Bump..... Not a mechanic by trade but that obviously doesn't sound good. Easy to be a Monday morning quarterback but did you get a written receipt/guarantee? Buyer beware! Hopefully It's not a big deal. Hope things work out for ya.......
Old Oct 24, 2011 | 06:16 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Sounds like my 97 Saturn when it dropped a valve seat into the cylinder. Are you losing compression and do any of the spark plugs have a bent electrode?
Old Oct 24, 2011 | 08:20 PM
Car: Camaro!
I pulled out the spark plugs on that side (It's coming from the Driver's side, if it wasn't obvious...), and they all seemed to be just fine. I guess a double check could be in order.. And I didn't get to check the compression in time, shortly after the video ended the car just kind of sputtered and died. I wasn't exactly too comfortable with starting the car up again after that.
Old Oct 24, 2011 | 08:53 PM
torque_is_good's Avatar
whoever put in the engine for you, did they not adjust the rockers correctly, did they forget some push rods or are the cam lobes that worn?
Old Oct 25, 2011 | 01:36 PM
Car: Camaro!
The push rods look fine... I checked them, and they are all there, I even pulled them out to make sure they were in sound shape. It didn't even cross my mind that it could be the Cam lobes, though, I've never heard a sound like this.
Old Oct 25, 2011 | 02:38 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
hard to tell, but it sounds like the valvetrain making noise.
Old Oct 25, 2011 | 03:08 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Originally Posted by Camaro_91_00
, I even pulled them out to make sure they were in sound shape...
Really sounds like the rockers need adjusted.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Gordonr1973
Sep 29, 2015 11:59 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
