gen 1 sbc wit lt1 heads an intake
Old Oct 29, 2011 | 08:37 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
can i use a gen 1 sbc with a lt1 setup my gf is looking to do a 3rd gen lt1 swap to her 86 trans am she got the car for 1000 dollars with a spun bearing 305 but the guy also gave a 2 bolt main disassembled with the rotating assembly no heads, cam, intake or distributor
Old Oct 29, 2011 | 08:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: gen 1 sbc wit lt1 heads an intake
Originally Posted by soarestransam
gen 1 sbc wit lt1 heads and intake
You could but the cost would out way the benefits.
Welding and machining required to make heads work
https://www.thirdgen.org/forums/post...55-post72.html
The LT1 intake however can be modified to fit on reg GenI heads
Needs a hole for mounting dist and ports for coolant that are not in the LT1 intake
https://www.thirdgen.org/forums/alte...-swappers.html
https://www.thirdgen.org/forums/alte...onversion.html
Old Oct 29, 2011 | 08:57 PM
Engine: LR4 4.8
i like that alot kudos to you on this picture looks like ill save this one if she wants to do that setup
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
