electrical problem. no spark.
Old Oct 31, 2011 | 07:52 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
awhile back i had something happen when i was starting my GTA. during mid crank, all the electronics died and the whole car was dead. i waited an hour before i tried anything again. everything worked except the starter, it would just click.
i had removed my engine after that to fix some oil leaks that had gotten worse. also replaced my battery ground wire because it was arcing to the block and thought it was just a bad ground.
everything is all ready to go and get ready to start it and nothing happens at all. starter doesn't even try. after messing around checking stuff, i find that if i just moved the ignition switch under the dash, the starter would work.
now got that figured out and fixed, and i don't have spark.
found that connector not connected to anything, but it looks like it doesn't go into the distributor, not sure where it goes though..
what are some procedures i can go through to test why i'm not getting any spark?
Old Nov 1, 2011 | 10:10 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: electrical problem. no spark.
Are you getting spark from the coil wire? If so, you're ignition module may have failed. If I recall correctly, the connector in your pic goes to the EGR solenoid.
Hope this helps!
Old Nov 1, 2011 | 06:22 PM
Engine: 350 L98/LS2
how do i test for spark at the coil?
Old Nov 3, 2011 | 01:48 AM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
Be careful and use either a spark tester or a old plug and hook it to the wire coming from the coil to the dizzy. It could be your icm or your dizzy that took a crap most common I've found out it's the icm
Old Nov 4, 2011 | 12:28 AM
Engine: 350 L98/LS2
is the icm located under the dash?
Old Nov 4, 2011 | 09:02 AM
clean92rs's Avatar
Car: 92 camaro RS
No it's in the dizzy, pull the cap off and you'll see it mounted to the base of the dizzy it should have two plugs running to it.
Old Nov 4, 2011 | 11:43 AM
grumpyvette's Avatar
http://forum.grumpysperformance.com/...hp?f=70&t=2798
http://forum.grumpysperformance.com/...ing+coil#p6656
http://forum.grumpysperformance.com/...i+meter#p16799
http://forum.grumpysperformance.com/...hp?f=32&t=1401
http://forum.grumpysperformance.com/...php?f=80&t=728
read thru these threads it will help
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
HoosierinWA
Oct 7, 2015 10:15 AM
