Oil coming out of exhaust?
Old Nov 2, 2011 | 11:46 PM
ptberg9's Avatar
Car: 1990 Trans Am GTA With T-Tops
Engine: 5.0 Liter F.I.
I have a 1990 Trans Am GTA and when i start it after it has been sitting for a couple of hours, a ton of white smoke comes out of the exhaust and it smells like oil. It never happens if it is just started up after a couple of minutes of it being turned off. Any ideas of what it might be? my exhaust system is pretty rusted out, too, just saying.
Old Nov 3, 2011 | 06:25 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Oil coming out of exhaust?
If it is just on startup it is usually a sign of needing the seals and possibly the guides replaced in the heads.
Old Nov 3, 2011 | 03:35 PM
ptberg9's Avatar
is there a possibility in cracked heads?
Old Nov 3, 2011 | 04:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is that possibility. White exhaust smoke typically means water, while light blue smoke is oil.
Old Nov 3, 2011 | 09:09 PM
ptberg9's Avatar
i know that it is definately smoke. i mean it REEKS when it starts up. i know much about engines but is it expensive and/or labor intensive to replace the seals and guides?
Old Nov 4, 2011 | 05:25 AM
3rdgenmaro's Avatar
Car: 88 IROC
Seals can be done with the heads on the motor. All you do is pull the valve cover, rocker arms, and springs.
Guides will require you to take the heads to a machine shop. At that point depending on how the bores look and how many miles is on the motor, it may be a good time to freshen up everything.
Old Nov 4, 2011 | 08:55 AM
ptberg9's Avatar
okay thanks alot! my dad is a master service tech at a dealership so ill just take it in there and see what all needs to be done. he smelled the smoke and assumed cracked heads so after what you said, there might be hope! haha
Old Nov 4, 2011 | 12:41 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Valve seals really aren't that big of a deal. Very common for these to go bad and puff at startup. Don't worry about it unless you're burning off tons of oil or you just can't handle it.
But as mentioned with a little work you can replace them with the engine on the car. Not a simple easy job but not the worst either.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
