700r4 trans not kicking down
Old Nov 6, 2011 | 12:00 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Hi guys have 89 formula l98 car runs strong 700 r4 trans car rips the only problem is when i am driving around 30 or so mph and punch it the car does not seem to down shift, once in a while if i put my foot through the floor i can get it to grab i believe is first gear and than the car seems to move out any help would be great thanks
Old Nov 6, 2011 | 01:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700r4 trans not kicking down
Should be in Trans dept
https://www.thirdgen.org/forums/tran...ns-drivetrain/
Is the TV cable adjusted correctly?
https://www.thirdgen.org/forums/post...742-post3.html
http://www.cpttransmission.com/tech_tvcable.htm
Old Nov 6, 2011 | 01:35 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok checked the tv cable seems to be ok can't push any more in any other suggestions thanks
Old Nov 6, 2011 | 06:06 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You push it in and then open throttle fully; that sets it in correct position.
Does trans still shift strange after TV reset?
BlueIroc-Z
Jun 9, 2019 03:22 AM
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Aug 6, 2015 04:15 AM
