Coolant temp sensor and Unknown sensor..
Old Nov 9, 2011 | 11:44 AM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Hi,
I located my coolant temp sensor between spark plug one and three. I was wandering if someone could provide me a picture of what the plug looks like that goes on it. I don't think this is the right sensor though because on another post someone said it was this one
http://shop.advanceautoparts.com/web...ntent=10711125
and the one in my car has a circle top? There is a wire thats broken and not connected to anything. The connector piece is flat and orange could this be the wire. A picture would help thanks.
There is also a sensor or what looks to be a sensor on the passenger side in between the 6th spark plug and the 8th. Its broken so I have no idea what it is or what it ever looked like. Can someone give me some insight on what this is!?! It would be cool if someone responded today so I can go buy the pieces I need.
Also is there a wire that connects to my knock sensor and what should that look like if there is one?
Thank you!
Old Nov 9, 2011 | 11:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Coolant temp sensor and Unknown sensor..
Between 1 and 3 is the coolant temperature gauge sender. Between 6 and 8 is the secondary fan switch. The coolant temperature sensor is on the water neck.
Old Nov 9, 2011 | 12:16 PM
xxZ28xx's Avatar
Thanks second question. The secondary fan switch I read up on it a little bit.. So my fan turns on automatically when I start my car. Do I still need that sensor if my fan does this? Im not too sure if there is two fans like a hidden one inside my radiator idk the post I was reading was pretty confusing.
Old Nov 9, 2011 | 12:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You might have only one fan.
Old Nov 9, 2011 | 12:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
A hidden fan in the radiator, Huh who knew !!!
Old Nov 9, 2011 | 02:13 PM
xxZ28xx's Avatar
New to cars calm down haha. I still need to know what the wire looks like that connects to my coolant temp sensor (the one that makes my gauge work)
Old Nov 9, 2011 | 02:18 PM
Engine: Lb9
Transmission: M20
answer above !
with koeo you can ground it and the ect gauge will max out
Old May 12, 2018 | 11:05 AM
DNW3576's Avatar
Car: 1983 trans am 305 crossfire injecti
Engine: 5.0
Transmission: 700r4 with overdrive
Axle/Gears: 3.75
Sorry missed a picture This is the newer one which is 2mm higher in deck height not the old one
Old May 12, 2018 | 11:30 AM
Already answered in your other thread
Old May 12, 2018 | 01:25 PM
Sscamaroboy's Avatar
I have the same problem.on my 82 camaro z28 305.had it for 20 years now lol.I have a green wire that had a plastic clip that broke and my temp gauge doesn't work.so were on that sensor does my wire connect to? Thanks
Old May 12, 2018 | 08:29 PM
Connects to the temp gauge sending unit. Driver's side head, between #1 & #3 spark plugs. Same place as you see em in the OP's photos. Probably has the "mushroom" style terminal on it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
