Check Engine Light???
Old Nov 9, 2011 | 06:20 PM
NeNick95's Avatar
Engine: 5.0 TBI
Okay so my 1991 camaro rs 305 check engine light will not come on
I took my gauge cluster out and check all the bulbs the bulbs were in good condition
Even if I turn the ignition on the lights come on expect the dang Check engine light
Can someone help me with this situation
Old Nov 9, 2011 | 07:31 PM
84transam87's Avatar
Re: Check Engine Light???
this is not vehicle specific for your car but i found someone that had mentioned this on another forum that might help...
There are fuses that directly affect the CEL light. Also, if a ECU ground is not proper, the CEL will not come on, if there is no power to the ECU, the CEL will not come on.
Every manufacturer has their own wiring system - check the schematics for your fuses, the locations, etc. and the procedure for ECU diagnosis.
Old Nov 9, 2011 | 07:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/elec...ine-light.html
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
