92 rs problems
Old Nov 17, 2011 | 02:08 PM
BftCamaro's Avatar
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
92 rs problems
hey hello im new here im 17 will be 18 tomorrow but thats besides the point i just gave my camaro a tune up and by tune up i mean changed the fuel filter, distributor cap, rotor button, spark plugs,spark plug wires,air filter,o2 sensor,belt,pcv valve and the starter and i had my master mechanic friend look me over and the car ran like a champ.Then about a week later it shut off on me in the middle of the street. i let it sit for about 5-10 mins and it cranked right back up then just 3 days ago it shut off on me again. the car cranks but does not turn on and when it does turn on it idles bad,and runs rough. from 0-30mph it runs really slow but when i hit about 40 mph its like something happens and the car just starts running correctly. PLEASE HELP ME.
Old Nov 17, 2011 | 09:54 PM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
Re: 92 rs problems
did you happen to change you ICM? they are common for going out. i was driving one day and mine just shut off and leave it sit for a day or so and it would run again, come to find out the pick-up went out in the dizzy.
Old Nov 18, 2011 | 03:34 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
Re: 92 rs problems
no not yet idk where it is could you let me kno
Old Nov 18, 2011 | 04:31 PM
clean92rs's Avatar
Car: 92 camaro RS
Re: 92 rs problems
If you take the dizzy cap off you'll see a black module that's your icm
Old Nov 18, 2011 | 05:47 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: 92 rs problems
Could be clogged Injectors but I dont know. I'm 17 too haha.
Old Nov 18, 2011 | 06:43 PM
clean92rs's Avatar
Car: 92 camaro RS
Re: 92 rs problems
If it dies on ya again pull a plug and test for spark. If it was more of a injector problem I'd think it'd be consistent.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
