Minor rough idle - something more?
Old Nov 18, 2011 | 03:08 PM
joef2002's Avatar
gang - 88 TPI; to my dismay I haven't driven Mt GTA much this year. When I do, it runs like a champ. Starts right up, no issues while cruisin. Occasionally though, he's idled a bit ''rough'. When I initially start it up, the car seems to run fine. After sitting in the driveway warming up a few minutes it sometimes does a very minor surge....like it almost wants to stall but doesn't. The surge doesn't last more than a minute or two, and eventually goes away...usually never coming back again during that ride.
Sometimes when I come to a light or stop sign, and let my foot of the brake to get moving, the car will again do that minor surge where the engine comes somewhat close to stalling. But even this is very random, and almost never happens.
And again let me stress - this "surge" that I'm describing is extremely minor. I don't need to press hard on the gas pedal to get rid of it, and it usually corrects itself if I just sit there. It's only happened on a few occasions the past 2 months, and when it does happen, the car never officially stalls. But it's almost like it's the early stages of symptoms that will worsen over time, and I'm wondering what it could be. Any suggestions?
Old Nov 18, 2011 | 08:39 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Minor rough idle - something more?
You could data log using ECM programs like Tuner Pro, Or Tuner Cat, but anything faster than their data sample rate will be lost, but the good thing is you can data log while driving.
You say during warm up it can last up to 2 minutes and that it does happen sometimes during stops so you should be able to catch it.
FYI
The data logger sample rate is divided among the number of systems you attempt to log.
If you log just 1 system you get about 10 sample per second, versus 2 samples for 5 systems per second.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
