Distributor & Carb Replacement question
Old Nov 23, 2011 | 10:46 PM
JTS's Avatar
JTS
Car: 83 Z28, 85 Burb
Engine: 305 Carbureted
Transmission: 5 Speed
I just want to make sure I'm on the right track with what I'm doing to my car. (83 Z28, 305 w/5spd) The PO swapped out the distributor for a regular HEI unit. I remember then he said he had to start messing with the carb. In order to get things right, I need to get a non computer carburetor, right?
Old Nov 24, 2011 | 07:09 AM
Damon's Avatar
Re: Distributor & Carb Replacement question
Correct. If you go non-computer controlled on eithr you do both.
Old Nov 24, 2011 | 08:08 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Why not put back the correct cc dist to get things right?
Old Nov 29, 2011 | 01:48 AM
JTS's Avatar
JTS
Because I'm not sure about what's been hacked out or just missing. I'm sure there is a reason the PO swapped out the distributor, I just can't remember right now. I have an edelbrock q-jet I'm going to rebuild and put on there...got the carb for free.
Frozer!!!
Jan 19, 2024 04:55 PM
pimp2303
Jul 27, 2017 02:03 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
