Having trouble pushing my car
Old Nov 28, 2011 | 07:08 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Put the key in the "on" position. I put it in neutral and made sure the emergency brake was off but it still only goes forward a couple inches then bounces back like it caught something. I was able to spin my wheels with them off the ground a couple days ago, why won't the car move when I push it? It was just me pushing and another guy steering. Does it really take a group of people to move this thing?
The engine is seized up.
I'm trying to get my car facing the other way because it will make using an engine hoist much easier.
Old Nov 28, 2011 | 07:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Having trouble pushing my car
take out the drive line.
Old Nov 28, 2011 | 07:43 PM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Even with the motor locked up the car should go into neutral and you should be able to push it. You might have a trans issue if you cant move the car more than few inched in neutral.
I agree with above. Remove the drivesahft and it will move.
Old Nov 28, 2011 | 07:59 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Other thoughts: Is there an under-inflated tyre that has developed a slight flat spot while sitting - hard to get 'em rolling. Nothing on the floor you are running over?
Old Nov 28, 2011 | 09:58 PM
0pyders's Avatar
oh yeah i bet my tires could use some air. They've been sitting for 2 years. I'll get them to 32 psi and see if that works.
Old Nov 29, 2011 | 10:07 AM
torque_is_good's Avatar
if air isn't the issue, then drop the driveshaft. If it's still difficult, then the rear brakes are engaged
Old Dec 2, 2011 | 09:04 AM
0pyders's Avatar
Filled the tires to 32 (they were around 22) and got 2 extra people and got it done. Thanks for the help.
Old Dec 3, 2011 | 12:12 PM
imjustsean's Avatar
Car: 91 rs
Engine: 305 tbi
I would just like to point out, with an automatic you can put it in any gear to roll it other than park because the torque converter isn't spinning to build pressure to engage the clutches inside. Useless info but there it is.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hokis
Aug 9, 2015 03:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
