Brake Line/Fittings question
Old Nov 29, 2011 | 06:03 PM
JTS's Avatar
JTS
Car: 83 Z28, 85 Burb
Engine: 305 Carbureted
Transmission: 5 Speed
The PO installed a rear end from an 85 IROC on my 83 Z28. They were not able to hook up the brake lines before I got the car. I tried messing around with it a little bit and I can't get the brake lines to thread in the junction block. Are they different from 83 to 85? Thanks!
Old Nov 29, 2011 | 06:19 PM
ex-x-fire's Avatar
Re: Brake Line/Fittings question
Is the junction block part of the rear brake hose? See if they are the same part#.
Old Nov 29, 2011 | 08:48 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 83 fittings are probably SAE, while the 85's are metric.
JamesC
Old Nov 29, 2011 | 09:03 PM
JTS's Avatar
JTS
JamesC
That's what I was afraid of. I didn't spend too much time on it, I just figured I would see if it was a quick fix before I continued on swapping out the bellhousing on my car...finally able to convert it to a hydraulic clutch. Looks like I'm going to be looking for fittings to adapt the two together.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
