bbc heads
Old Nov 30, 2011 | 05:26 AM
454cutty's Avatar
bbc heads
need some opinions from the big block guys...which would u say has more power potential the 781 oval port heads or 990 square ports
Old Nov 30, 2011 | 06:41 AM
Re: bbc heads
The 990s will "make more power".
About 90 - 95% of all cars that have ever had them, have gone slower than with something else.
At low RPMs the square ports are all-around worse. Their virtues don't show themselves until very high RPMs, and the RPM where they turn from a net loss to a net gain depends greatly on motor size. At anything less than about 6500 RPM in a 454, they hurt overall performance.
In general, this is one of those things where if you have to ask, you don't need to go there, besides just curiosity. The physics will beat the romantic 60s hot-rodder lore every time.
Old Nov 30, 2011 | 06:59 AM
grumpyvette's Avatar
Re: bbc heads
http://maliburacing.com/patrick_budd_article.htm
you might find this link above worth reading thru
and Id also point out that there are far better heads available than either of those listed factory big block head castings
TRICKFLOW,BRODIX,AIR FLOW RESEARCH and PROFILER all produce far better heads, any of the better aftermarket heads matched to the correct compression ratio, cam, timing, intake type,and rear gear ratio can easily produce 70-90 hp more than untouched factory castings, and both the factory cast heads and aftermarket heads can be significantly improved with careful port work
Old Nov 30, 2011 | 02:53 PM
454cutty's Avatar
Re: bbc heads
i was jus curious i have a 1987 cutlass supreme with 40 over 454 small domes comp 292 and a set of 781 oval ports already done up with bigger 2.19 1.88 setup mostly a street car wont see too much over 6500 i think im jus gonna do some bowl blending and porting with what i got and maybe a solid cam upgrade screw square ports... thanx man
Old Nov 30, 2011 | 02:55 PM
454cutty's Avatar
Re: bbc heads
yea i know there are better heads out there im just on a poor mans budget haha i think im jus gonna port my 781 heads thanx for the input man
Old Nov 30, 2011 | 08:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: bbc heads
Your 781's are perfect for that. You'll lose power if you try that with 990 heads. The 2.19/1.88 valves with some port work will make a big difference over the stock heads.
My engine uses rectangular port heads but the operating range is 6200-7500+
Old Dec 1, 2011 | 09:36 AM
454cutty's Avatar
Re: bbc heads
thanx man nice factory l98 camaro u got
Old Dec 1, 2011 | 07:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: bbc heads
There's very little factory anything left of my car.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
