Spark Plug Help
Old Nov 30, 2011 | 09:38 PM
midwestkid's Avatar
Spark Plug Help
Trying to figure out what spark plugs I should run with my new motor..
Specs:
350 4-Bolt Main .030 over
Scat 400 Crank
Stock 350 Rods
.030 over Pistons
COMP Cams Hydraulic Flat Tappet (.480 int/.480 exh 290/290 duration )
CNC-Motorsports Roller Tip Self-Aligning Rockers
Stock 350 Heads (1.94 Intake Valves/1.50 Exhaust)
Professional Products Crosswind Air Gap Intake
Holly 650 Street Avenger Carb
Can anyone help me out? Let me know if you need to know anything else.. I think I almost covered it.
Old Dec 1, 2011 | 12:14 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Spark Plug Help
Specs:
Scat 400 Crank
Stock 350 Rods
.030 over Pistons
Most of that doesn't matter, but the compression and type of heads does matter. You didn't say what year heads, or better yet what casting number?
If they are typical stock Chevy iron heads around 1989-ish, then you
will run this size plug:
14mm thread
11.6mm (0.460") reach
with a tapered seat.
In that case I would start out with an Autolite 24
for break-in and initial tuning.
For WOT tuning and full 1/4 mile passes on the motor I would switch to
Autolite 144
For a power-adder that gives less than a 25% power increase, I would use an Autolite AR12.
If you are going to be using a power-adder that gives over a 25% power increase, then you might want to consider switching to Autolite AR135 plugs.
For long-reach or gasket-seat plugs the part numbers will all be different from what I listed above.
Old Dec 1, 2011 | 01:44 AM
midwestkid's Avatar
Re: Spark Plug Help
They are as you described, a stock iron 350 head.. I'll try and pull casting numbers tomorrow. Compression ratio should be between 9:1 to 9.5:1..
There won't be any power adders on this motor and it will only be very occasionally used for 1/4 mile passes. Thanks for the help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
