305 camshaft help!!
Car: 87 iroc-z, 89 dakota sport
Engine: 305 ci
Axle/Gears: 3:27
305 camshaft help!!
Hey everyone i have an 87 iroc with a 305. this winter i am rippin off the heads and doing a valve job. id like to put in a more aggressive cam. i want to gain some hp and get that loppey idle. what is a good cam with out running into tuning issues. I have typical bolts on now. shorty headers, true duals no cats. bbk throttle body, cold air, b&M shifter and shift kit. any help would be greatly appreciated. Thanks!
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
Re: 305 camshaft help!!
the best cam for thre buck and for a 305 is the lt1 cam with new valve springs get the cam from here or ls1 form around 50 bucks for a used cam
If your car has the automatic trans from the facotry then it's got the "peanut cam" in it, as it is called around these parts. It's an itsy-bitsy little sucker with specs of 179*/192* @ .050 and lift well under .400" on both intake and exhaust.. Yes, that's LESS than 180* duration and lift that doesn't even register on the performance radar. Just about anything will be a "fire breather" compared to it, even very mild performance cams. The factory LT1 cam would be a good example.
You may be tempted to over-cam it if you stare too long at aftermarket performance cam specs. Resist that temptation. Even a very mild cam like the factory LT1 cam (about 202*/206* duration @ .050) is a HUGE change over the original cam. The MAF-equipped EFI systems like were used on the earlier TPI engines are pretty good at adapting to larger cams without requiring custom programming. But they have their limits. And a 20* increase in cam duration is going to test those limits even though the cam is still going to idle very smoothly.
Car: 1986 Irocz
Axle/Gears: 3.25:1
get a lt1 cam thats the best one or call compcams see what they have to offer.
Engine: 305 ci
Axle/Gears: 3:27
yeah i keep hearing from everyone is to go with the factory lt1 cam. so can i get that new from say summit racing? and what aplication to i use as in year make model?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I've heard good things about the Lunati 60102 and 60103 cams for the 305. Easy to find on summit's web site to check their specs.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Check classified on a few forums where the LT1 is common.
I think even LS1tech has a LT1 section.
There are some forums for Impalas as well.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
