Sending Unit Line Size
Old Dec 16, 2011 | 03:10 PM
madigidy's Avatar
Car: 89 iroc z restoring
Engine: from 5.0 to 5.7
Transmission: from Auto to 5spd
hello third gen fam
does any one know the size of the stainless steel lines that are on top of the sending unit. i want to splice into them to remove the unit without dropping the tank. now before some of you get all "willie nellie" thinking i am going to hack up the car i plan to add a panel just incase i decide to go bigger on the motor later. i promise it will look nice...
thanks for your help...
Old Dec 16, 2011 | 07:07 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Sending Unit Line Size
to do the access panel "right" youll need to drop the tank anway. the feed line is 3/8ths the return line is 5/16ths and i think the vent and evap lines are also 5/16ths.
Old Dec 17, 2011 | 01:45 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Once you have the tank out you'll see that having to make a couple of twists and turns to remove the sending unit you'll be glade you did, as I did when my pump pooped. I installed an access port and coupled the lines, and glad I was, as six months later in 2002 my new 255lph Holley pump didn't live up to Holley's rep. Installed a used one out of an '85 in less than 30 minutes with a few choices words while navigating the pump out of the hole. Don't for get to replace the inlet filter sock.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
