low octane=misfire?
Old Dec 18, 2011 | 11:41 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
low octane=misfire?
Is it possible that using a low octane on an old 305 can cause a misfire? Maybe if i used 93 octane, it would stop?
I changed all the plugs, wires, and it still misses on the 8th cylinder sometimes.
I don't think its a bent valve.
Old Dec 19, 2011 | 07:32 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: low octane=misfire?
No, no chance at all.
Old Dec 19, 2011 | 07:38 AM
torque_is_good's Avatar
nope
if you don't have a roller engine then it could be a worn cam lobe
it doesn't hurt to try the cheap stuff first, cap and rotor
Old Dec 19, 2011 | 12:52 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
low octane = possbile detonation, not a missfire. it could be a bad wire, plug, or a bad spot on the cap.
Old Dec 19, 2011 | 05:46 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
but i already replaced the cap, plugs, wires...
Its the number 8 cylinder. It misses.
I don't want to waste my money on a 305 either, so if its a camshaft, i'm gonna have to junk it.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Jan 10, 2020 08:55 PM
327IROC85
Sep 23, 2015 12:11 AM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
