Is it worth going to 8mm plug wires on semi-stock ign. system?
Old Dec 20, 2011 | 11:32 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
My ign. system is stock with the exception on a brass terminal cap and rotor. Is it worth "upgrading to the 8mm's? Or will the spark be just as strong with the 7mm's?
Also, any recommended spark plugs for the L98(TPI)?
It really is a pain to do all this work on this engine, i dont want to have to do it again for a while!
Old Dec 20, 2011 | 11:51 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: Is it worth going to 8mm plug wires on semi-stock ign. system?
My opinion is to save your money.
Old Dec 21, 2011 | 12:03 AM
Kdizzo977's Avatar
Car: 87 Trans Am GTA
I had 7.5 mm spark plug wires & moved up 2 8mm it smoothed out tha idle plus it did make a difference when accel...
Old Dec 21, 2011 | 12:04 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
It is a pain to change the plugs but I can get it done in about 30 minutes with a lift.
Old Dec 21, 2011 | 08:05 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
cheap carbon core wires start to break down/deteriorate from date of mfg. . a new set of wires off the shelf in a parts store may in fact be a couple of years old . a premium brand will be much better & last longer . worth the difference in price ? to me it is , i would rather pay a few bux's more and not have to wonder . i have a full MSD system on my car . dist. 8366 , wire kit (8.5mm) 31229 , coil 5526 , i'm happy . the old story you get what you pay for (i feel) is true . what ever you do , good luck .
Old Dec 21, 2011 | 08:26 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Zero difference.
If it "runs better" then your old wires were bad to start with.
Old Dec 21, 2011 | 01:12 PM
torque_is_good's Avatar
they cost under $40 at Summit or Jegs so it's not like we're talking a huge expense. In fact, they are cheaper than some OEM sets at the local parts store
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
